Question for the 6 limited owners on the forum
Greg
Denver
2024 Tacoma Hybrid Limited
I can confirm that my Hybrid Limited has AVS as standard and not an option. I double-checked this prior to purchase because it wasn’t obvious.
Greg
Denver
I’ll add that I was originally excited for SPORT S+ mode before I got the truck. Since getting it, I’ve found myself using COMFORT mode more than anything. Unexpected for sure, but that setting makes for a truly amazing ride.
Randyg
Randy
OK
2024 Bronze Oxide LTD; 2008 Speedway Blue Off-Road
Mine is an LTD with AVS. To Customize, go to Vehicle Customize, Custom drive mode, and change settings there. Click on each option and pick your choice. As you can see, I changed my options.
2024 Tacoma Question for the 6 limited owners on the forum IMG_5101
2024 Tacoma Question for the 6 limited owners on the forum IMG_5102
2024 Tacoma Question for the 6 limited owners on the forum IMG_5100
2024 Tacoma Question for the 6 limited owners on the forum IMG_5099
Greg
Denver
Has anyone found documentation that explains which settings get what configurations for each of the default AVS modes? I haven’t been able to find anything of the sort.
I figure I need to know what the default modes do to have any idea how I’d want to setup my custom mode.
jan123
pacific northwest
2024 tacoma limited
Mine is an earlier Limited (purchased in March 24), and it does not show the Custom Drive Mode option in the Vehicle customization menu. Also, it does not show Air Conditioning in the Custom mode when I access it from the top of the screen after selecting the "custom" mode.
Clearly, yours has a newer version of the dashboard software. I'd like to get that, but Software update shows that no updates are available.
Tacomanoob
Daryl
4G Tacoma
On my menu I dont have custom drive mode. Is this only for HYBRID
4g hybrid
Custom was an available drive option in the ICE (non hybrid) Limited trim I test drove. And that was at a dealership back in the middle of June (so let's guess an April build date?)
jan123
pacific northwest
2024 tacoma limited
Yours must be an early manufacture date. Mine does not have it either (VIN around 1,500). I recently checked a truck on a dealer's lot with VIN around 44,500, and it had it. It seems to be a software bug that Toyota apparently fixed in trucks that are being sold right now. My dealer contacted Toyota, they said they are aware of the problem and are working on a solution. As of now, there is no software update available, though.
4g hybrid
For those with custom challenges there is a TSB for your AC unit (I think it was) to be reprogrammed to fix it.
That said, anyone else notice that custom is the only mode that doesn't "stick" between power off cycles (meaning the next time you start the truck, it details to normal)? For me every other mode holds between starts
