Trailhunter onboard air compressor and 4-tire inflation/deflation hose
mfat
Kansas City
4th gen
Has anyone used a 4-tire hose with the Trailhunter's on board air compressor yet? If so, what are your opinions as to how it performed?
Thanks!
mfat
Kansas City
4th gen
Interested in this also
I ended up buying a moorflate 4-tire system which works well. It takes around 7 minutes to take all four stock tires from 18psi to 33psi.
RichP64
Rich
Las Cruces, NM
2024 Tacoma Trailhunter
Decided to DIY it, all parts off Amazon, mostly Flexzilla components. Used exactly one 50' hose cut to appropriate lengths. No leaks, works as I expected, only takes a couple of minutes to set up and keeps all 4 tires at the same PSI.
2024 Tacoma Trailhunter onboard air compressor and 4-tire inflation/deflation hose 1
2024 Tacoma Trailhunter onboard air compressor and 4-tire inflation/deflation hose 2
2024 Tacoma Trailhunter onboard air compressor and 4-tire inflation/deflation hose 3
2024 Tacoma Trailhunter onboard air compressor and 4-tire inflation/deflation hose 4
2024 Tacoma Trailhunter onboard air compressor and 4-tire inflation/deflation hose 5
Pootklopp
Usa
2024 Bronze Oxide TRD OR
That is awesome. Mind giving a parts list for all of it?
RichP64
Rich
Las Cruces, NM
No Problem, though it probably isn't cheaper than the Morrflate you can find on Amazon, I like DIY and was able to make the connections and lengths exactly what I wanted.
Bucket Boss bag - $18.99
Flexzilla fittings -$3.99 ea (x12=$47.88)
25 piece fitting kit - $23.99
50’ Flexzilla hose - $28.72
Airhose connector 2 pack $19.19 ea (x2=$38.38)
Locking collar air chucks 2 pack $15.99ea (x2=$31.98)
Total $189.94
EDIT: Weird, looks like it stripped out the links, but easily searchable on Amazon.
