Turning off power tailgate
So I figured out how to turn off the power tailgate on my info screen and when I do it seems I can manually open the tailgate .. but when I try to close it, I’m pushing against the motor. And if I let go it stays frozen in mid air. This seems off. I thought it would behave as a normal tailgate with the power turned off. What’s going on?
SnowmanJPS
Halifax, NS
2025 TRD Pro
I don't have an answer for this, but I am hoping people make kits to delete the power part of the tailgate, not something I'm at all interested in
Bluznvice
West
I think you need a different truck. Maybe something from the 60's.
Did you try just unplugging it?
Instructions for disconnecting the wires are in your owner's manual, since it's a required step for removing the tailgate entirely when needed.
AZTaco
AZ
2025 Tacoma TRD Pro
Even when you unplug it, you will still feel the motor.
Mine is starting to glitch / get stuck from time to time when opening … will be on my warranty items next oil change
AZTaco
AZ
2025 Tacoma TRD Pro
I recently added a seal to my tailgate to keep dust out (I have tonneau cover). Compressing the seal when you closed the tailgate (with power) caused the tailgate to stop about an inch short of latching. After sitting closed overnight the seals stayed compressed enough that the power close functioned properly. The sensors are that sensitive. Dirt or debris may be accumulating somewhere causing enough resistance to make the power function stop for "safety" reasons.
rybern
Ryan
Albertville, AL
'25 TRD OR, 00 Taco 4wd, '21 Corolla XSE
The power tailgate is the only feature that I wish I could have opted out of on my incoming '25 TRD OR. I'm sure I'll learn to like some aspects of it but it seems the power tailgate will cause some unwelcome gremlins and issues. I'd be very interested in power delete if I end up having any issues.
Bcphoto3
Bill
Oak Ridge, TN
What did you do to seal the tailgate? I tried several kinds of foam, but after being in the SW for a month, the very back of the bed is covered in dust (Have an AluCab Contour Canopy).
AZTaco
AZ
2025 Tacoma TRD Pro
I have a RetraxPRO (which I love) and started with the ESI Ultimate Tailgate Seal. I didn't follow their directions. I removed the tailgate and put one continuous strip on the bottom (as opposed to three pieces), I didn't put the pieces on the top (#3A, 3B, 3C) because it looked stupid, and I initially did 4B but it started to fall off so I removed it. Instead I used some edge seal and edge trim to seal those areas. Seems to be working pretty good.
