Wind Noise - Whistle and Rattle
Jabstep
Southern USA
Has anyone noticed a slight whistle near the drivers side when you get close to 70 mph? I'm also getting a rattle on the passenger side. Both seem to be around the A pillar.
Goombah
Mark
Wow, 70mpg is amazing - I'm only getting 20.8mgp. LOL - I'm sure you meant 70mph, but just couldn't ignore it. :)
As for the whistle, I haven't noticed it. Will pay closer attention and am interested if others are experiencing the same.
Burgi
NC
24 Taco
Has anyone noticed a slight whistle near the drivers side when you get close to 70 mpg?
between 70-75mph while you’re lightly on the throttle? And then it stops as soon as you let off the gas?
if so that’s the differential howl. Mine is currently at the dealer getting a new differential
Jabstep
Southern USA
Bump - just seeing if anyone else has experienced this? I'm bringing it into the dealer today. The rattle is similar to TRD Jon's Tundra videos.
Tacomanoob
Daryl
4G Tacoma
How many miles do you have that you are experiencing this. I just hit close to 2000 miles so I will check to see if the truck has a rattle and sound as well. One thing that irritates me is the build quality is not what it used to be. I had every generation of tacoma and when I take apart all individually you can definitely tell that the build quality goes down with every generation.
Jabstep
Southern USA
Dealership claimed they found it. It’s the trim pieces on the room and they’re replacing them. I’ll update once I get it back.
Fiigtaco
TRD OR
I’ve had this wind noise twice not sure what it is but it definitely isn’t consistent
Jabstep
Southern USA
I'm having issues uploading a video but I don't believe the dealership has found the issue as they claim. I tapped down the trim pieces they claimed to be the issue with some painters tape and I'm still hearing the wind noise.
The driver's side is a whistle and the passengers side is a rattle. Both seem to be near the bottom corners of the wind shield.
Marbach92
Uchiha!@22
2024 Toyota Tacoma
passenger
I have the same issue it drives me crazy. Rattle starts for me around 50mph and gets louder. I can’t pinpoint what it is. Here is a video of what mine sounds like
Jabstep
Southern USA
Mine sounds exactly the same but on the passenger side. It did get a little better but oddly enough its gotten better after I've installed the OEM bed cover. Its probably coincidental.
Plymouth MA
2024 Tacoma TRD Turbo automatic
Plymouth MA
Yes I have the same issue and driving me nuts. Not the whistle but the rattle. Only at speeds above 65 MPH. Only on passenger side somewhere over dash. Dealership service thinks it is outside air turbulence??? Test drove another 2024 Tacoma TRD with the Service manager and it also had similar sounds. All tape and foam tests (images below) had no effect except the taping of the passenger window seals (inside and out). I left the painter's tape on the window. Then, the next day, without removing the painter's tape, the 'rattling noise' returned!!!
