My first mini mod was to Plasti Dip my front chrome Toyota emblem. I used a feeler gauge to gently pry out the emblem without breaking any of the tabs. It was quite easy and I only had to pry in two place. It's best to stick the feeler age in between the plastic and the emblem at a straight angle and then slowly work your way around until you feel resistance where the tab is and then gently pry a little to pop that section and then do one of the others. I like the finish and will have to wait and see how it holds up to rocks hitting it. I applied three coats.
