Dipstick reading
Hey guys - I had my dealer do a break in oil change and after I checked the oil level. On one side of the dipstick it was super high, but on the side it looked only a tiny bit high. I feel like a dipstick for even asking this. But is that normal? I noted this on my 22 Tacoma as well. Is it just the sale of the dip stick tube catching more oil on one side?
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Yeah, that's typical, it usually takes me 2-3 tries to get a reading that I trust.
Edit: I find it easiest to check the oil first thing in the morning before the engine has run. You are supposed to check it warm, so I wouldn't want to see it all the way to the second dimple. I like mine just over half-way between the two.
It’s definitely over the second dimple no matter how I check it (though I’ve not checked it cold yet). I’ve got a siphon - should I remove some? Also, this dealership always overfills - with the last Tacoma they did the same thing and told me the machine just decides how many quarts to spit out when they enter the model into the computer. So I’m perplexed. Next step is to check it cold and I’ll report back.
2024 TRD Sport-Bronze oxide
Every vehicle I’ve owned was always higher on one side. Don’t know exactly why. One thing I did was sand the dipstick with fine sandpaper to make the level stand out more. Painting it a flat black would probably be best, but I don’t know how it would last submerged in oil constantly.
It’s annoying because before the oil change I think it was reading between the lines from the factory. Oil pressure gauge seems fine. Caps out at 3/4 bars when I floor it, a little over 2 bars when coasting at steady speed, down to almost zero when hybrid turns off engine.
Edit: I’m going to pull out dipstick and let it sit for 15 minutes so the oil in the tube drains then try it. Will report back.
I have had good luck just wiping it down and trying again, until I get a consistent reading. I don't know why this is so hard, but I have had this problem on multiple vehicles, particularly the different reading from side to side.
@soupy1234 I haven't read all the manual - it is huge - but I'm surprised it calls for checking it when warm. I have seen this in other engines though but it makes this process even harder.
It keeps reading high. Wondering if I need to siphon. It’s about 1/8” to 1/4” high.
Why don't you check with your dealer and see what they say? Is that 1/4" above the top mark on the dipstick?
I did. They gave me “oh it’s fine” routine after a 20 year old change the oil, is why I despise the dealership and why I’m going to start changing my own oil. Dealer competence is low and their give a fuck factor even lower. It should be simpler to confirm.
StreeTaco
A little overfill isn’t going to hurt anything. It will help keep the oil in better condition. If it’s killing you , just go ahead and siphon, or drain, to your liking.
What’s a normal range for the oil pressure meter
Oil pressure ranges differ from one engine to another, and I don't know what an acceptable range is for this turbo 4. Are you worried about your oil pressure being too high or too low? In my experience having rebuilt engines many times, overfilling won't make your oil pressure higher. I agree with @StreeTaco that you are probably fine, but just siphon some out if you are worried.
I haven’t rebuilt any engines. So I’ll take your advice. I was thinking it was too high (just drove the truck seems to bounce from about 1.8-3.2 out of 4). I’m also just frustrated that every toyota dealer is crap. I’ve got low trust based on prior experience.
Yeah, my opinion of dealer service is not a lot higher than yours, so I do understand.
But every engine I have rebuilt had an oil pressure relief valve. In many engines it is just a small piston which pushes against a spring in a cylinder. When the oil pressure overcomes the spring, the piston moves and that opens a port. That releases the oil pressure into the sump until it drops back into a normal range.
Excess oil pressure could cause all manner of problems, which is why engines are designed to not ever let that happen.
Warm engine. Allowed oil to drain back into pan for 15 minutes. 2 readings showing both sides of the dip stick. For some reason one side always shows more (I assume because of engine camber).
2024 Tacoma Dipstick reading IMG_5463
2024 Tacoma Dipstick reading IMG_5464
2024 Tacoma Dipstick reading IMG_5465
2024 Tacoma Dipstick reading IMG_5466
