Mako_Shark27
Looks like you're fuel started to cut out and a throttle body got stuck open causing the lean code and the first code. Then probably as it was throwing codes something got messed up in the crossfire and that was your turbo sensor reading too highGreat question. I didn’t even look at that. Here is the report I got:
None of those codes are on the TSB. So if this wasn’t transmission related then WTF happened?? I’m actually more concerned now! Haha
