Randyg
Randy
OK
I did originally think water was coming in through the tailgate side gaps. I made these seals out of 5/16” x 1” Black Vinyl Foam weatherstrip tape. Fits perfectly. Does not interfere with auto tailgate
2024 Tacoma OEM Trifold Hard Tonneau Cover PT954-35240 installed on 2024 Tacoma IMG_6012
2024 Tacoma OEM Trifold Hard Tonneau Cover PT954-35240 installed on 2024 Tacoma IMG_6013
2024 Tacoma OEM Trifold Hard Tonneau Cover PT954-35240 installed on 2024 Tacoma IMG_6014
Mpflies2
Marc
Georgia
What did you use to adhere the foam to the sides? I’ll keep this in mind if I have any significant leaks
Randyg
Randy
OK
It is self-adhesive.
Mpflies2
Marc
Georgia
thank you! Took a screenshot and added as a mental note for if it leaks. I forgot to check before I left the house this morning and it had down poured overnight. I should’ve looked into it.
sjfuqua
Alexandria, VA
OEM cover + bed mat + divider?
So I have read through this thread 3 times before posting my question.
Just installed the OEM cover with OEM Tacoma bed mat. Very happy so far and made my decision after reading this thread.
Looking to purchase and install the OEM bed divider next.
From this thread I understand the divider will have to be trimmed about 3/4 from each side, and there is about a 3/4 inch gap between the 'lowered' divider and the floor of the truck bed without a mat. (and given the mat is about 1/2 inch a 3/4 gap seems ok but close)
Before I pull the trigger looking for a definitive, has anyone installed the OEM cover, with the OEM mat, and the OEM bed divider (modified width) and does it fit? Any issues?
Thank you and glad to be a new member to this forum.
jimmy115
Jaime
Oregon
Tacoma TRD Off Road 2024
Same question
sjfuqua
Alexandria, VA
Same question
So I installed the OEM divider in my TRD Offroad today with OEM bed mat and OEM trifold cover.
The answer is yes it fits with about 1/8 in gap between the bottom of the divider and the mat. (at least in the middle of the bed where I placed mine).
Similar to what others have said I needed to cut 1/2 in off each end of the divider.
I also needed to cut 1/2 in off each of the two brackets so that the divider and welds fit between.
I found the aluminum to be soft and easily cut on my miter saw with fine tooth carbide tip blade. Left a clean cut. May paint the cut edges in the spring, but since it is aluminum not worried about rust just about appearance.
Very pleased with the outcome. Photos attached.
2024 Tacoma OEM Trifold Hard Tonneau Cover PT954-35240 installed on 2024 Tacoma IMG_3255
2024 Tacoma OEM Trifold Hard Tonneau Cover PT954-35240 installed on 2024 Tacoma IMG_3256
2024 Tacoma OEM Trifold Hard Tonneau Cover PT954-35240 installed on 2024 Tacoma IMG_3257
2024 Tacoma OEM Trifold Hard Tonneau Cover PT954-35240 installed on 2024 Tacoma IMG_3258
2024 Tacoma OEM Trifold Hard Tonneau Cover PT954-35240 installed on 2024 Tacoma IMG_3259
2024 Tacoma OEM Trifold Hard Tonneau Cover PT954-35240 installed on 2024 Tacoma IMG_3260
