Fang Light install, why is everyone pulling the fender /bumper apart instead of doing this
32spoke
Jason
Petaluma,CA
Is this guy magic or something?
Not in my opinion, using a T-tap is like using a wire nut, also this person ran into an issue between using a fuse tap for a ATM vs and ATM LP…. It is what it is.. not a fan of t-taps, but ok since LED lights can illuminate off of 9 volts.. but I would seal it, even if it looks like crap.
Slappy
tacoma , highlander
yeah ! i gotta show this video to Nave motors . they wanted to recalibrate the adaptive cruise control sensors after pulling the front end to install these (with a $700 recal trip to the dealers)
I still want these installed 🤤🫤
32spoke
Jason
Petaluma,CA
I am in the automotive industry… I know a guy that can do this if you’d like… not to take work away from Nave Motors, but this guy’s work is excellent and he is reasonable
evlfred
evlfred
Monte
Idaho
yeah I wasn't really commenting on the wiring, it's not good. I was referring to reaching through from the top to remove the stock "vent" panels. If i were going to use the turn function (I'm not) I would probably de-pin the connector and replace the pin with a new one and both wires into the one pin. I don't plan on even connecting the turn function as I have the sequential turns in the headlight and I think it would look off.
Yotota
Zane
SW WA
24 TRD
Janky wiring aside... The clips for that trim panel would likely be too weak to hold a high quality, aluminum housing light like a Baja Design or equivalent. I like that spot though, and I hope more manufacturers make use of it for auxillary lighting. But adding more marker lights just for aesthetics isn't really my thing.
Suzay
Hawaii
2024 Tacoma sport
I think not much have done it this way because it’s time consuming. I’m sure the guy doing this video edited the video to make it seem easy. Also taking the bumper off makes it easier to route wires and tidy it up before putting bumper back on. I’ve done mine and it was easy peasy taking the bumper off. Plus I can still use my original black insert (since I didn’t break the tabs) if the fang lights fail
