Hood insulation
Gfenza89
Gary
2022 tacoma sr5
Can you elaborate more on this rubber stripping on the rear door, I like to reduce all noise.
Go to your local Toyota dealership and look at some higher trims, you’ll see the gasket I’m taking about. That’s gonna be the best way to see it, you can also order them from your dealerships parts department
bresna
2024 TRD Sport
Ordered the OEM insulation and clips yesterday. Got everything for ~$250. Will report back after I install it.
Where did you find the insulation and clips for $250? Most places want at $300 just for the OEM insulation.
Slappy
tacoma , highlander
So is that thin black strip visible with both door closed ??
Love to see a close up detail photo that shows the shape of the seal . I guess i will go over to the dealership & see if I can find a model with the seal
