Hood insulation
Gfenza89
Gary
2022 tacoma sr5
Can you elaborate more on this rubber stripping on the rear door, I like to reduce all noise.
Go to your local Toyota dealership and look at some higher trims, you’ll see the gasket I’m taking about. That’s gonna be the best way to see it, you can also order them from your dealerships parts department
bresna
2024 TRD Sport
Ordered the OEM insulation and clips yesterday. Got everything for ~$250. Will report back after I install it.
Where did you find the insulation and clips for $250? Most places want at $300 just for the OEM insulation.
Slappy
tacoma , highlander
So is that thin black strip visible with both door closed ??
Love to see a close up detail photo that shows the shape of the seal . I guess i will go over to the dealership & see if I can find a model with the seal
Wahhabm
Monther
Thanks for the photo. It seems some aftermarket weather stripping can work also.
I just went to the dealer and they provided part numbers below. There is actually 4 of them. 2 on front door and 2 on rear door. Yes, they are visible when the door is closed.
67895-AK010
67896-AK010
67865-AK030
67866-AK030
the dealer wanted $26.+ for each plus tax amounts to $114 roughly. I decided to wait for when toyota offers a sale.
Yep - you can see them when the door is closed - they just fill up the gap between the panels and I never really notice them. There is also a gasket between the back of the cab and the front of the bed, but I don't know which trims it comes on.
