4g Tacoma MPG and Fuel Tank Size SUCKS!!!
hogshooter
Corey
Plant City, FL
2024 Tacoma Limited 4x4
I'll be the first in line when a larger tank is released. My old Tundra with the 36 gal tank could make it from FL to TN on a full tank, that's my goal with the Tacoma.
32spoke
Jason
Petaluma,CA
OP, I can drive from my home to Sonoma county, to Boron-on 1 tank of fuel, same as my gen 3 L4 AT Tacoma.. I don’t like doing it because the fuel pump is cooled by fuel. I guess I don’t see a problem with the mileage, but I also tend to drive without recruiting the turbo unless necessary- That is a 403 mile trip btw..
CrispyTacoLover
I like my 2024 Offroad a lot. I probably have the wrong tires on it, but they will be tested the next 48+ hours. After that I’ll assess whats next.
HrĂ­mfaxi
2021 Tacoma AC
Hmmmnn...they do make trucks that use zero gas....if gas tank size and mileage is your thing
They do, personally like the Rivian over the Tacoma, however range takes a nose dive when loaded and/or towing. Recharge time is slow. Tank size is all about range for me.
The new Scout hybrid sure is intriguing though (500 mile range!) similar looking to the Rivian but better looking headlights/grill, definitely like their offerings over how Toyota did their truck hybrids. More practical usability than just a power boost.
Will they ever see production is the question.
deder808
David Eder
Hawaii
2024 Off Road Premium 4x4
I get about 375 per tank my second gen struggled to get 300 with a larger tank super impressed with the fourth gens mpg.
bking
Bernie
2021 F150
Sometimes I wonder if they are putting smaller tanks/range in these trucks to get us ready for electrics. I personally like the idea that GM had with the Volt and is now being used by BYD which is using combustion engines as generators to move electric motors. I think BYD uses Diesel (which will probably never happen here). It's an excellent idea that would pave the way to replace the generator with a fuel cell, etc... as technology improves. If electric were better, I'd for sure go that way. You just can't put electricity in a can.
HrĂ­mfaxi
2021 Tacoma AC
I am getting just as many miles per tank as my 2007 PreRunner
How many miles are you getting per tank?
Prerunners should do better than the 4WD. Guessing you’re on stock tires and unladen?
These trucks do “ok” in stock form for running around town. It is when you start putting on bigger tires, loading them down for traveling is when the small tank is going to be annoying. Toyota markets these trucks as adventure rigs, their slogan is “Let’s Go Places”, just don’t go too far. Ha!
My plan was 34” tires, pop up camper plus towing a small enclosed trailer. mpgs won’t be the best.
Wonder the same since they put the tank on the passenger side and did the wacky exhaust routing.
The new Land Cruiser 250 that shares the same chassis, gets a diesel in the overseas market, there is a DEF tank on the drivers side.
Could use that spot for an auxiliary tank in the Tacoma.
2024 Tacoma 4g Tacoma MPG and Fuel Tank Size SUCKS!!! IMG_4554
bsquaredMTB
El Paso, TX
2016 Tacoma TRD Off-Road
Not trying to be a pain here but I always wonder why people buy vehicles they might not be happy with. Tacomas are admittedly expensive and have some compromises (the gas tank being one of them). If you knew this going in, I think it's hard to make the argument that the truck sucks. My thought is, you have a really capable truck. So you have to fill up a few more times, no big deal. Just my two cents. Not trying to start a battle here lol.
HrĂ­mfaxi
2021 Tacoma AC
They Tacoma has a long history of people trying to make it do what it wasn’t designed to do. People wanted bigger, so they made it bigger, (some say it is too big now) they wanted more power, so they gave it more power, people wanted better fuel economy, they gave it better fuel economy yet low end torque suffered, people wanted better fuel economy plus low end torque, they gave it that, but took away range. etc, etc, etc…
It has always been a compromise truck that doesn’t do anything thing well.
Trying to please everyone plus pass government regulations is a monumental task. Toyota always seems to take 3 steps forward and 2 steps back with their trucks. They tend to miss some of the basics while trying to appease the masses.
The Tacoma is at its best iteration, yet there still are compromises.
GSteele
Gerald
North Carolina
2022 Bronco, 2024 4Runner, 1930 Model A
i have not yet pulled the trigger on a 4G. One concern is the small tank. I currently tow with my 4Runner, and that thing requires more stops for refueling than I like on a road trip. Following some ideas proposed in this thread I started looking at Toyota parts drawings. The 2022-2024 22 gallon Tundra gas tank looks lIke it would just about drop directly in. That is a minor improvement, however, the 32 gallon tanks appear to be possible if the exhaust is rerouted in front of the tank. I do intend to buy a long bed if/when I pull the trigger and I expect that will make it even easier to fit the largest tank.
Tacoma tank part: 77001-04240
Tundra 22 gallon tank part: 7701-0C170
Tundra 32 gallon tank part: 77001-OC160
