Routing usb power under dash for victory dash plate
Rozzi
Sam
Nc
2024 Tacoma trd sport
So I’m looking at this from victory and like the idea of having some mounting points behind the screen
https://www.victory4x4.com/product/...VyXPEuT15EG0WxHh_8dshMYzO6JGvabBKEaPKowHQA3sX
It comes with a dual usb cable and was wondering if any way to run that under that dash section for power or they’re just plugging it into the side of the screen? Would love to have power up there with a clean install
2024 Tacoma Routing usb power under dash for victory dash plate IMG_0899
2024 Tacoma Routing usb power under dash for victory dash plate IMG_0900
StreeTaco
2024 Tacoma TrailHunter
12v outlet in front of shifter for one
Rozzi
Sam
Nc
Mine shows up today. Following.
Same mines out for delivery right now so curious about the best way to if you find out a good solution let me know as well
Btimothy4
TB
Denver
You could also pull the power, ground from the JBL removable dash speaker charge wiring and make it really easy.
Btimothy4
TB
Denver
Happy to help, I ordered one as well
Here is the wires you will just need to tap into:
2024 Tacoma Routing usb power under dash for victory dash plate 1738121630928-zz
rchrds
TN, USA
2024 Trailhunter
Nice- I actually looked at tapping into the wire bundle on the back of the screen as that is right under the same panel, but this seems easier, and has less detrimental effects when the cable taps ultimately fail.
