I adjusted my front camera via the on board diagnostic service menu. I adjusted it +165 while parked in a place where there were lines and it all lined up. Although for some reason the view adjustment button is now greyed out and I can’t access it anymore.
How'd you get to this menu system?
rijc99
4G Tacoma OR Premium
Key on engine off - turn audio off - turn display off - swipe right 5 times swipe left 5 times.
Function check - Canera settings - View adjustment.
Make sure to park where there are plenty of straight lines in front and around your car for alignment purposes. Do the adjustment in one shot or don’t save.
Mine is greyed out because I already made an adjustment. So do it in one time.
2024 Tacoma Heritage Grill Camera Swap - Observations IMG_2704
2024 Tacoma Heritage Grill Camera Swap - Observations IMG_2705
2024 Tacoma Heritage Grill Camera Swap - Observations IMG_2706
2024 Tacoma Heritage Grill Camera Swap - Observations IMG_2707
taco4moro
Los Angeles
2024 Tacoma TRD ORP
wow thanks for finding this, the dealer was going to charge me a couple hundred $ to fix.
Which camera bracket did you use? Hoping to be able to fix the camera alignment perfectly as having the 360 view off bothers me so much.
rijc99
I used Rave’s bracket. Good luck with your alignment. Find a flat place with a bunch of lines or lay some stuff down and take your time.
