Beat Sonic, need feedback
hogshooter
Corey
Plant City, FL
2024 Tacoma Limited 4x4
I installed mine a couple of weeks ago. It makes a huge difference.
I could get mine to fit behind the screen until I took the removable speaker and it's dock out, and then it was straightforward. Removing the dock is also super easy.
Yeah - exactly where to place the amp is kind of skipped over in the Beat Sonic install video, and I will just have to figure that out. I had not thought about taking out that removable speaker/dock.
Hope to do mine some day this week when my time opens up a little.
hogshooter
Corey
Plant City, FL
Remove the speaker, and use a trim tool to remove the plastic trim surround. You'll see 4 screws to remove, then the dock just lifts straight out.
Josh256
Toronto, ON
2025 Tacoma TRD Pro
Thanks,
2T3 for +JBL.
Out of curiosity: If the 3T3 would be for 2018+ non-JBL then is the T330 a more powerful option for non-JBL 2024+ essentially?
@Josh, Meraki
Do you folks ship to Canada?
MERAKIAUTOWORKS
Joshua
Anaheim, CA
Thanks,
2T3 for +JBL.
@Josh, Meraki
3T3 would work as well for the JBL folks. BeatSonic is waiting to install at 3T3 onto my OR premium w/ JBL. They didn't mention it wouldn't work. I believe primary difference is it has a port for a sub connection.
Yes we can ship to Canada.
-Josh
moladin
Alexandria, VA
Toyota Tacoma, EVO X
I have a JBL system and installed the BeatSonic a week ago. I bought it directly from BeatSonic store. I wish I would have known about this thread prior to ordering it direct. Oh well.
I installed and removed a couple of times just to hear the difference, and I can say it is definitely an improvement. I left the gain at 1 o'clock for both front and rear. I think 2 o'clock was a bit much for me. I read somewhere on another forum that the rear gain doesn't to jack, but what the hey. :)
The bass is certainly punchier, and less muddle for the rest of the frequencies. It definitely plays louder at the same volume level prior to the install. I normally listened at 25 volume level stock, but now only about 15 after BeatSonic installed. I actually think it sounds better as you raise the volume, but then the doors' speakers start vibrating. I plan to do some doors' sound deadening once the weather permits.
Off topic, I wouldn't recommend replacing the dash speakers for a coaxial ones, I don't think the JBL system has the right crossover to work with coaxial speakers in the dash. I tried, and it sounded worst than stock. I am still debating whether or not I want to replace it with one way speakers for the dash. Most 3.5" and 4" speakers on the market are all coaxial, not much options for one way unfortunately.
Also, if you find that you lost sound from all speakers after the install, take out the head unit and reinsert all the plugs. Make sure they are all snugged. Do not pull the connectors from the wires, always from the plugs. I lost sleep because of this, even go as far as ripping my seat out to check on the JBL amp that sits right under the driver seat. I still don't know which plug(s) is the culprit.
Anyway, back on topic. Honestly I think $300 is a bit much, but we do not have a lot of options for plug and play. Overall I am happy with it and from what I gather, it is an easy return if you are not happy with it, as long as it is within 30 days for a full refund.
diverjm
Jordan
CA BayArea
24’TRD OffRoad
-Josh
Following as I have the JBL but wanted to add an external amp for a sub in addition to the factory setup w/BeatSonic but thought this wasn’t an option according to BeatSonics website.
2024 Tacoma Beat Sonic, need feedback IMG_7612
MERAKIAUTOWORKS
Joshua
Anaheim, CA
Yes confirmed with them it will work on the JBL systems as well!
Glad to hear this good feedback!!
-Josh
Vidman
Rick
Mass
I tried the amp back about 2 months ago. Still sounded like crap. Just made the muddy sounding system louder. Can’t distinguish the mids from the highs so the whole system was replaced. Couldn’t see having a crappy sounding system in my Trailhunter
I was hoping to provide some feedback, but I can't even get my Beat Sonic amp to work. I am fairly sure it was connected correctly, but the screen never booted up after hooking it all up. I watched the video again and checked the wiring schematic that came with the amp. Then I reconnected everything but still no screen.
I have it back to the factory connectors and everything is working again. I am just glad that I didn't somehow kill my screen and radio. Next I will talk to Beat Sonic about this, but I really don't see what I could do differently.
hogshooter
Corey
Plant City, FL
you probably mixed up the connectors. There are two or three connectors that will fit in the same port. Plus, the Beatsonic connectors aren't color coded as well as the factory ones. I had to double check everything twice before I was satisfied I had the right cables in the correct ports. Remove the Beatsonic, plug everything back in with colors, and make a note or take pictures of what goes where before attempting reinstall. Then, follow each cable from the Toyota end to the BS end and make sure they land in the right port.
That is pretty much what I did, and I took pictures of the back of the HU before I removed anything. That combined with it now working again without the amp makes me certain that the other connectors are in the right spots.
You only really need to remove the rest of the connectors when you are fitting the amp behind the HU. So on my second try I left everything else connected to the HU except the two connectors that get replaced by the BS connectors and then plugged the OEM connectors into the BS cable. It still didn't work.
When I removed the amp I just removed those two BS male connectors from the HU and reinserted the OEM connectors. It all works fine again now. I do plan to pull it out and recheck, but really it is just a simple swap of two connectors and I can't see how I screwed it up.
I'll post again after I recheck it, and thanks for the ideas.
hogshooter
Corey
Plant City, FL
I've also seen a few connectors in the Tacoma look like they're seated but have another 1/16 of an inch to go before they're really fully seated.
