- First Name
- Dave
- Joined
- Jun 9, 2024
- Threads
- 10
- Messages
- 205
- Reaction score
- 197
- Location
- Los Angeles
- Vehicle(s)
- 2024 Toyota Tacoma 4x4 Long Bed
you’re right. I totally forgot. I guess I’ll report back when mine get in. I have an sr5.Early on there were some issues with the mounting hole pattern being different on different trims. Anyone know if that has been resolved?
Did you put 34 or 35's on the stock wheel?Installed these today, installation was easy, instructions were accurate. Hardest part was removing the shipping label adhesive, but used some charcoal lighter fluid and it wiped right off. These should keep all gobbly goop out of those under-bed nooks. Cleaned up pic just for fun.
https://www.roughcountry.com/product/tacoma-rear-wheel-well-liners-4521a
34.5 on stock 18sDid you put 34 or 35's on the stock wheel?
That’s money.34.5 on stock 18s
Thanks I'm trying to decide what size wheel and tire set up for my off road.34.5 on stock 18s
Hard to explain exactly how they feel.. they are rigid but flexible.. to a point. I think they would crease if bent over 90 degrees to itself.@StreeTaco how flexible are the ARK mud flaps? Curious to see if they can withstand being pushed back with trail objects (rocks, ice, mud, etc.)
do you have a photo of how the front mud flaps mount? I’m curious to see if the ARK flaps would fit with the NYTOP carbon fenders and with the crash plates removed.
The rears aren’t installed correctly. They should tuck behind the metal fender lip.so the roughy country wheel well covers dont sit quite right on the sr5 (with no fender flares). I’ll live with it though.
The ARK splash guards fit perfect. Excellent quality.
Are you sure? I don’t have fenders. I don’t see how it would’ve fit otherwise. I can check though. It was bitch to install.The rears aren’t installed correctly. They should tuck behind the metal fender lip.
