OPINIONS ON LASFIT TURN SIGNALS. AND SNOW?
R00F_K0REAN
Tyler
NJ
Just some food for thought. something I noticed today coming home from work. I live in the northeast. And we are currently having some light snow. So I’ll preface this with the fact that I just recently replaced my halogen turn signal/running light? bulbs. For led ones. Coming home today on my 20mile trip home I wiped the headlights clean before departure and started to notice that my headlights became a billboard for snow to collect on. And had loss of light being thrown down the road. And I don’t think there was enough heat generating to melt any flakes laying on the lens. Now do I think a halogen would produce that much more heat? I don’t know. But something I took note of whilst driving. And while yes. I understand that maybe. At some point in driving under heavy snow. That may happen. And you’ll have to clear the lens off. But I’d argue what I was facing was no where near the worst I’ve personally seen so far in regard to flake size. And abundance of flake? If that makes sense. Opinions? I may go back to halogens for more heat build up in the housing
CrispyTacoLover
I thought Diode Dynamics implied that Lasfits bulb with the built in resistor generated a lot of heat, and their solution was superior.
I wish the headlight enclosure had defrost.
R00F_K0REAN
Tyler
NJ
I guess in all honesty I can’t blame or even point the finger at lasfit per se. It was one drive cycle under one set of weather conditions so I’ll chalk it up to coincidence for now. And see if I can get repeatable results before I make any assumptions. If that is the case though with diode dynamics. Then I don’t see why it wouldn’t work. Granted. I came from a 97 Chevy k1500 to a 24 taco. So I’m feeling spoiled but I’ve never had that issue with the rust bucket.
UT
This is a non issue. I'd be more worried about the snow collecting on the front radar.
R00F_K0REAN
Tyler
NJ
oh man. I already went through it. Thank baby Jesus Toyota allows you to make on the fly setting controls for the Adas. Systems. Couldn’t take the constant messages. Had to turn off parking sensors. Lane keep. And active cruise. But once turned off. I can live with it. Everyone else around me is driving like they’ve never seen snow before so I have to keep my wits about me
Vidman
Rick
Mass
I had custom made led headlights made for my tundra. supposed to be the best at the time but I couldn’t run them in the winter because they would just pack up with snow from lack of heat so I had to remove them till it warmed up. The lights were awesome but not for snow… just a thought
It depends on outside temps? If it’s 30 and snowing it’s going to stick to everything, if it’s 10 below and snowing it won’t stick to anything. I have the lasfit bulbs and definitely traveled through a lot of snow storms this year zero problems.
R00F_K0REAN
Tyler
NJ
so I started thinking. Maybe…Some sort of super hydrophobic coating? Or a tiny little heater element to keep the snow at bay? I’m grasping at straws here. Is there any way at all to disable the radar system?
2024 TRD Sport-Bronze oxide.
How long is a turn signal on? A minute or 90 seconds at a stoplight? Is a halogen bulb going to make that much difference in that amount of time?
UT
As sensitive as it seems to be, I wouldn't want to mess with it lol
CuriousTaco
Seattle
TRD OR Base
Although not the exact same behavior, I have a slightly related comment. I have the DD switchbacks installed. While driving through heavy snow a few weeks ago, forward visibility was terrible and ended up white knuckling for a few minutes. I started wondering if the switchbacks were worsening forward visibility in those conditions because of increased white diffused light protecting upward (no beam pattern). It made me consider swapping them back out for a full time amber led.. or now possibly amber halogen bulbs if the halogen bulbs actually end up producing more heat to help in snowy conditions.
Not-so-patiently waiting for the DD updated amber Stage Series fogs.. should only be another month or two.
R00F_K0REAN
Tyler
NJ
I ended up chalking it up to coincidence. MT-Taco does have a valid point. I did notice that switchbacks were available but i opted for the full time ambers and amber turns in LED. Definitely at the very least finishes what Toyota should’ve done in the first place but I digress. I’m keeping them in for now.
