disabling DCM / telematics in 2025 Taco
bobinoregon
Bob
oregon
2025 Taco
Posting a how-to on grounding out the antennas used by the DCM telematics module.
This post is not a debate about the puposes of telematics communicating data back to a toyota service center ,or legality of same -- only a how-to for those interested.
Background - why bother?
- All recent toyotas have a always-on cellular connection to Toyota corporate via thee internet. This enables lots of data reporting and remote monitoring & control of the vehicle. This includes GPS location, speed and other data. Maybe you don't care, maybe you feel the pros of being connected outweight the cons; but some people don't want this data being sent at all.
What data gets sent?
I Refer you to the 2024 service manual where it says:
2024 Tacoma disabling DCM / telematics in 2025 Taco aaaa
2024 Tacoma disabling DCM / telematics in 2025 Taco bbbb
The HOW-TO for those interested:
I know that on other Toyota models, pulling the DCM fuse results in a Check Engine Light. I Haven't tested this on my Taco; but i don't want a bogus CEL masking other legit causes for CEL. So i looked for a method to keep DCM communicating to ECU but not the outside world.
After some research I found this thread. This method takes less than 15 minutes and is completely reversable. Basically unplugging three oem cables and plugging in three terminated dummy cables which tell the DCM it's out of range for cellular and GPS. This does NOT affect any other cellular or GPS devices you might have in the vehicle.
First, I looked up the location of the DCM module in my 2025 Taco. It's behind the phone shelf/charging area just ahead of the shifter.
I purchased three 'Fakra Z Female to SMA Female Vehicle Antenna Adapter cables' and some 50-ohm SMA terminators off Amazon. The square Fakra Z shells on the jumper cables need to be removed leaving just the inner coax connector, becuase the Fakra shells are are too Fakrin' wide to fit into the Toyota DCM. Do this carefully so as not to damage or bend the inner coax connector fins.
Accessing the DCM is easy; the panel holding the phone shelf/Qi charger basially pops forward and unclips. Once loose it can be pivoted to the right allowing acess to guts of the console. The DCM is front and center.
2024 Tacoma disabling DCM / telematics in 2025 Taco 1_IMG_8358.JPG
2024 Tacoma disabling DCM / telematics in 2025 Taco 3_IMG_8360.JPG
The antenna leads are on the left:
2024 Tacoma disabling DCM / telematics in 2025 Taco ant
The latches for the connectors are at the front. I suggest using a right-angle tool such as a pick to push the latches inwards while tugging gently on the cables. They pop out easily.
2024 Tacoma disabling DCM / telematics in 2025 Taco 5_IMG_8363.JPG
Install the terminated jumpers into the three DCM sockets you just freed up. The connectors have a slight interference fit so they won't easily fall out.
2024 Tacoma disabling DCM / telematics in 2025 Taco 8_IMG_8368.JPG
You could probably? just let the jumpers dangle in the dash area but i wanted to take their weight off the interference-fit coax connectors at the DCM side. So I used an ahdesive-backed zip-tie mount and a zip tie stuck right to the front of the DCM, through wich i looped the three new jumper cables. Now there is no weight pulling down on the connectors landed in the DCM.
2024 Tacoma disabling DCM / telematics in 2025 Taco 9_final
I Pushed the three OEM cables back into the dash and let them dangle.
I started the truck at this point to check for any CELs... no problems found.
Reinstall the phone shelf/carger plate in reverse sequence. Start the bottom with the vertical fin connectors.
That's all there is to it. At this point the DCM will this it is out of range for both cellular and GPS.
Note: the OEM "emergency assistance"button and other "connected services" are now diabled, obvi, as it requres that built-in cellular link. I infer that pulling the onboard GPS antenna also functionally blinds the onboard oem navigation. If you use onboard oem Nav, the you could experiment with reconnecting the GPS antenna only I guess? YMMV.
This will NOT affect any carplay, cellular or GPS accessed via a paired smartphone.
2024 Tacoma disabling DCM / telematics in 2025 Taco 7_IMG_8365.JPG
ramble22
2024 Tacoma Limited Hybrid
Fantastic info, thanks for sharing. I opted out of Toyota telematics shortly after purchasing the truck, but will be doing this as well since I don't have full faith the the opt-out will be fully honored long term.
bobinoregon
bobinoregon
Bob
oregon
2025 Taco
That's a hell of a lot of work to wear a tinfoil hat, however I really do appreciate these forums for what people are able to figure out
Here are two articles on data collection and how auto makers are sharing your data with insurance companies:
1. https://www.komando.com/tips/privacy/car-companies-collecting-data/
2. Automakers Are Sharing Consumers’ Driving Behavior With Insurance Companies
"What it contained stunned him: more than 130 pages detailing each time he or his wife had driven the car over the previous six months. It included the dates of 640 trips, their start and end times, the distance driven and an accounting of any speeding, hard braking or sharp accelerations. The only thing it didn’t have is where they had driven the car."
Dirt
Greg
Eastern OR
Damn!
UT
And this is exactly why I disabled mine in the dealership parking lot before driving the truck home. Not that I went as far as you did lol.
Still blows my mind that people are willing and gladly PAY Toyota to give them all of their driving information (locations/speeds/trips/ etc.).
Sancheesy
Shawn
Ontario
Thank you for doing the work. I saw a youtube video on this data tracking.
TrustButVerify
Several
A point about why this matters. I got a call from the dealership the other day. "We noticed your truck has just over 5200 miles but hasn't been in for its 5000 mile service."
Apparently in the 40 screens of fine print, somehow I agreed to share all my driving info with the lowest form of life on earth, a dealership. I just wanted to use the remote start. They decided to spam me with emails and calls as a thank you.
Dayen
Daniel
North Kingstown RI
2024 Tacoma SR 6MT, 2004 BMW 325i 5MT (for sale), 1985 BMW 316 5MT
Do we expect the modules to be located differently in any way on a MT car? I have the parking brake bezel that goes over half the surface the panels on a AT car cover
ShawnJon
Fresno
Did you loose your microphone doing this mod? I have the fuse pulled and there are no check engine lights but I lost the microphone. Has anyone rewired it differently if youve run into the sane problem?
