I'm a bit confused on the wiring setup. For my Limited, if I purchase the pigtails and switches is the wiring installed to plug into or do you need the OR or sport?
I'm showing the list price is $116, ~$83 from a discount dealer. Also, I seem to recall there are 4 part numbers.Switch Auxiliary Di - Toyota (84484-AK040) is the factory aux switch how ever they are back ordered and toyota say they are 200 and up a peice there are other places for around d 120 and below
Plug and play harness can be purchased from Specialty Performance Parts (SPV). They can give you connectors wiring harness and other stuff. Ask for John. I am not a paid endorser. I have bought 3 in the last two monthsWhich company had a wiring harness on their lights that was plug and play with the pre-wired Tacoma pigtails? Cali Raised LED says they can't make theirs plug and play and still requires some splicing, which doesn't make much sense to me. Did Toyota use some super proprietary connector or what?
Not to burst your bubble but I think the 24-25 harnesses are indeed different. Adding an Aux 4 switch will require more wiring than just plugging it in. The 24s only have 3 relays and 3 fuses relating to the aux switches.Greetings I just joined the forum last night, as I found out from one of my wiring harness dealers SPV about the forum; but to the question of the auxiliary switches: on my 2024 trail hunter, it only has 3 AUX Switches. See photo. The 2025 Trailhunter has four switches. The part number for Aux4 above is correct (Aux 4: 84484-AK040) as I called my local Toyota dealer this morning, and he said it is on back order and more than two weeks out for $129 including tax. I told him I don’t care how long it takes. I need a fourth switch as the Trail hunters are all wired the same way they just didn’t include the 4th switch on the 2024 model. There are four “ports“ on the vehicle, two under the hood, one in the driver, left foot side panel, and one on the frame in the rear. The plugs are all the same using Toyota supplied pigtails on higher level, trim packages. I am using plug and play adapters that I purchased from Specialty Performance manufacturing in Indianapolis.(SPV). Ask for John. And this is not a commercial for them. I just happened to buy some rigid ditch lights last night as I am staying with the rigid brand since the trail hunter has rigid fog lights, and grill light bar.![]()
I will find that out on Friday. My local dealer has 2(!) TH's on their lot. Will open one up and look.Not to burst your bubble but I think the 24-25 harnesses are indeed different. Adding an Aux 4 switch will require more wiring than just plugging it in. The 24s only have 3 relays and 3 fuses relating to the aux switches.
Interesting. I just took delivery of my '25 TRDOR today. I know I only have Aux 1-3. I'll look to see if there is a powered Aux4 relay slot, and if the Aux4 fuse slot is powered.Not to burst your bubble but I think the 24-25 harnesses are indeed different. Adding an Aux 4 switch will require more wiring than just plugging it in. The 24s only have 3 relays and 3 fuses relating to the aux swi
tches.
