AUX Switches easy to use / hook-up!
I'm a bit confused on the wiring setup. For my Limited, if I purchase the pigtails and switches is the wiring installed to plug into or do you need the OR or sport?
Norman
Norman
Virginia
24 tacoma trd or
Switch Auxiliary Di - Toyota (84484-AK040) is the factory aux switch how ever they are back ordered and toyota say they are 200 and up a peice there are other places for around d 120 and below
Pappy
Albuquerque, NM
I'm showing the list price is $116, ~$83 from a discount dealer. Also, I seem to recall there are 4 part numbers.
Aux 1: 84484-35010
Aux 2: 84484-35020
Aux 3: 84484-35030
Aux 4: 84484-AK040 (84484-35040)
I was at Overland Expo this last weekend in CA. Toyota had a Trailhunter on display. It had the Aux 4 switch installed. Make me wonder how the truck is wired, and if they have different pigtails to wire them up.
TFOUTS
Timothy
Northwest Florida
2024 Tacoma Trailhunter, 2003 Tacoma TRD , 2003 Toyota Sequoia
Greetings I just joined the forum last night, as I found out from one of my wiring harness dealers SPV about the forum; but to the question of the auxiliary switches: on my 2024 trail hunter, it only has 3 AUX Switches. See photo. The 2025 Trailhunter has four switches. The part number for Aux4 above is correct (Aux 4: 84484-AK040) as I called my local Toyota dealer this morning, and he said it is on back order and more than two weeks out for $129 including tax. I told him I don’t care how long it takes. I need a fourth switch as the Trail hunters are all wired the same way they just didn’t include the 4th switch on the 2024 model. There are four “ports“ on the vehicle, two under the hood, one in the driver, left foot side panel, and one on the frame in the rear. The plugs are all the same using Toyota supplied pigtails on higher level, trim packages. I am using plug and play adapters that I purchased from Specialty Performance manufacturing in Indianapolis.(SPV). Ask for John. And this is not a commercial for them. I just happened to buy some rigid ditch lights last night as I am staying with the rigid brand since the trail hunter has rigid fog lights, and grill light bar.
2024 Tacoma AUX Switches easy to use / hook-up! IMG_4941
TFOUTS
Timothy
Northwest Florida
Which company had a wiring harness on their lights that was plug and play with the pre-wired Tacoma pigtails? Cali Raised LED says they can't make theirs plug and play and still requires some splicing, which doesn't make much sense to me. Did Toyota use some super proprietary connector or what?
Plug and play harness can be purchased from Specialty Performance Parts (SPV). They can give you connectors wiring harness and other stuff. Ask for John. I am not a paid endorser. I have bought 3 in the last two months
2024 Tacoma AUX Switches easy to use / hook-up! IMG_4950.JPG
StreeTaco
2024 Tacoma TrailHunter
Not to burst your bubble but I think the 24-25 harnesses are indeed different. Adding an Aux 4 switch will require more wiring than just plugging it in. The 24s only have 3 relays and 3 fuses relating to the aux switches.
TFOUTS
Timothy
Northwest Florida
I will find that out on Friday. My local dealer has 2(!) TH's on their lot. Will open one up and look.
Pappy
Albuquerque, NM
tches.
Interesting. I just took delivery of my '25 TRDOR today. I know I only have Aux 1-3. I'll look to see if there is a powered Aux4 relay slot, and if the Aux4 fuse slot is powered.
TFOUTS
Timothy
Northwest Florida
So I went to my dealer today and looked under the hood of the 2025 TH relay/fuse box on driver side and took a photo. 1st photo just below is the 2025, the bottom one is mine 2024. It looks the same as my 2024 TH relay/fuse box
2024 Tacoma AUX Switches easy to use / hook-up! IMG_4958.JPG
2024 Tacoma AUX Switches easy to use / hook-up! IMG_4955.JPG
StreeTaco
There’s another fuse box on the passenger side engine bay, maybe it’s over there
TFOUTS
Timothy
Northwest Florida
We looked and there was AUX5, then AUX 4 H and L. I did not have that. Need to get more info. I installed my ditch lights and plugged in the DT connector from SPV into AUX3 which is the "C" plug in the engine compartment, and currently waiting on UPS to deliver the harness this afternoon. When I get it I will post
