I have a feeling there isn’t one.I can confirm moving it to the left side of my gauge cluster did nothing. The search for solutions continues
sigh… yeahI have a feeling there isn’t one.
Good old scammer—I mean service departmentsWell I took it in to the dealer and they determined it's "working as designed". I find it ridiculous that that's the ONE SCREEN that won't stick. It's obviously a bug but I doubt Toyota will ever look at this
what is the single meterSo if you only use the "Single Meter" and not the default "double meter" with the rpms & mph it seems to stick.... But that's the only way I've seen it consistently stay how I set it...... But I don't like the look of the single meter
"Meter Type" in settings. Types are dual analog meters (the default), a single analog meter (speed or rpm) in the center of the display, or numeric speed in the center.what is the single meter
There was a comment about making sure you move the cursor back to the center before hitting the 'back" button to exit settings. Have you tried that?I can confirm moving it to the left side of my gauge cluster did nothing. The search for solutions continues
That doesn't work... I tried that also.... It may work once or twice but it still goes away after a couple of start upsThere was a comment about making sure you move the cursor back to the center before hitting the 'back" button to exit settings. Have you tried that?
