Front window tint % to match back windows?
B-52 Gunner
Gerry
Lansdale, PA
I'm thinking of getting the two front door windows tinted.
My "tint" guy said 20% should match the back windows and 35% is a nice transition if I don't want to go too dark..
What do you guys recommend?
CrispyTacoLover
I have 35% on mine. Your back windows didnā€™t come from the factory at 20%.
2024 Tacoma Front window tint % to match back windows? IMG_1015
rmc983
Phoenix
2025 Tacoma Limited
Just had mine done yesterday and went 20% in the front and 35% in the back. This was the installerā€˜s recommendation to make the frontā€™s better match the back privacy glass.
2024 Tacoma Front window tint % to match back windows? IMG_2003
bigd9247
WA
2024 Tacoma TRD OR Premium
I did 35% on the front. They're a little bit lighter than the rear windows, but I'm happy with the end result. The tint shop I used metered the rear windows at around 25-26% if I remember correctly.
f7eleven
MD
'13 FJ Magma,'23 4Runner TRD PRO Solar Octane,'24 Tacoma OR LB Solar Octane
if you tint the front at the same % as the rear - the front will look lighter because they're right next to the windshield.
tinting the front windows will also make the rear windows look darker, since the rear is getting less light through the front now.
you definitely want to go darker on the front if you want the front and rear to look the same.
20% is pretty good. that's what I got. I wish I had gone one step darker on the front, so probably 15%.
B-52 Gunner
B-52 Gunner
Gerry
Lansdale, PA
Thanks, I'm wondering how 20% effects night driving?
Vidman
Rick
Mass
Whatā€™s legal in your state
goin2drt
KY
Rear is right in between what most tint shops have. They usually go 25 then 35. Rears are about 32. However as stated above when the fronts get tinted they even out the back when doing 35%. Personally unless you have great eyesight and your night vision is also perfect then 20% starts making it dangerous at night in my humble opinion. I would not do anything darker than 35.
Forest Moon
Michael
MA
2024 OR Supersonic Red MT
I doubt that's accurate as it would be illegal in some states. Here in MA, front and back side windows are the same, 35% is the legal max.
BAQ717
ā€˜24 Tacoma TRD OR
Thoughts on doing 30% all around? I am pretty OCD and donā€™t want to try and match the windows perfectly as thatā€™s nearly impossible. Iā€™m okay with the front being a bit lighter.
bigd9247
WA
Maybe her meter wasn't calibrated right. She tried hard to convince me to go 20% on the fronts, but I went 35% because my OCD is ok with the front windows being lighter than the back, but not the other way around... go figure.
Wighty
Rob
OC, CA
2024 TRD Pro
Just remember.. the rear windows aren't "tinted". It's privacy glass. So it doesn't keep much, if any, heat out. I put 70% ceramic on the back window, rear windows, front windshield and 20% on the front windows
2024 TRD Sport-Bronze oxide.
Learn something new everyday. I thought all tinted windows were the same. Privacy glass offers little more than clear glass as far as heat and sun protection.
