Brunson
J
Queens
'19 Explorer
So this is how you can easily gain 2" of turning clearance to fit bigger tires on the 2024 Tacoma. You just have to remove this crash bar bracket.
Steps:
1. Remove the mud flap
2. Remove felt cover
3. Remove bolts from steel bracket to remove from body mount
Note: the braacket is called a crash bar and helps prevent the tire from coming into cab in a collision.
PHOTOS:
Bracket Removed
2024 Tacoma How-to: get bigger tires clearance on 2024 Tacoma -- bracket removal DIY bigger tires  2024 Tacoma no rub remove crash bar bracket 1
Bracket, Mud Flap, Felt Cover Removed
2024 Tacoma How-to: get bigger tires clearance on 2024 Tacoma -- bracket removal DIY bigger tires  2024 Tacoma no rub remove crash bar bracket 2
Stock Clearance Measured
2024 Tacoma How-to: get bigger tires clearance on 2024 Tacoma -- bracket removal DIY bigger tires  2024 Tacoma no rub remove crash bar bracket 4
Clearance Gained After Removing Bracket
2024 Tacoma How-to: get bigger tires clearance on 2024 Tacoma -- bracket removal DIY bigger tires  2024 Tacoma no rub remove crash bar bracket 3
Here's an example (vide) of a bigger tire fitted after removing the bracket:
17x8.5 -12 RRW wheels with 285/70/17 tires fitted on stock 2024 TRD Sport suspension.
Credit to C Rupp for the photos/info.
TalkingTaco444
Earth
How does this impact warranties or insurance claims in the event of a crash?
Am new to the lift/tire game and am honestly asking.
GL Rockwell
George
Floreeda
20 tacoma OR
33s are fine with me, in the event of a wreck from all the dumbasses on the roads I'd rather not have an emergency tire removal surgery.
joemysterio
Hayward, CA
Subaru Forester Wilderness
Good to know. I most likely won't be going so big that I have to start removing safety devices/parts.
Everything TRD
Oh man I really wish RRW makes the RR7-H in a more friendly offset for the 2024 Tacoma. Something around a +20 would be nice and hubcentric. Any pictures of the amount of poke from that -12?
Visa_Declined
OKC
TRD Off Road
That tire size fits easily without removing the bracket, also.
Duane
Duane
Newfoundland Canada
2020 tacoma trd sport
hmm...not sure about removing a crash bracket. would insurance deny coverage in the event of an accident if safety equipment is removed?
Visa_Declined
OKC
TRD Off Road
I wouldn't have a problem removing the cab mount bracket if I was trying to run 34's or 35's, that's why they made it removable in the first place. Most 33" setups are fine though.
2024 Tacoma How-to: get bigger tires clearance on 2024 Tacoma -- bracket removal DIY YzExJIs
w00die
Scott
Virginia
Gen 4 Tacoma SR5
Where did this fitment chart come from? Thanks.
Jdunlap12
Justin
Charleston, WV
2024 Tacoma SR5
Steps:
PHOTOS:
Bracket Removed
What you going to do with front and back mudflaps?
Mykale220
Georgia
2020 Off-road (cement)
Put them in a box with random parts that I no longer need, but still probably won’t sell, just in case I ever need it. But I won’t….😂
2024 TRD Sport-Bronze oxide.
Here's a guy that put 35's on his Tacoma and MPG has dropped to 15. Also it runs hotter and he thinks it will greatly shorten the life of the turbo.
Link
