Shock blown through the top while driving down paved road 😡
JBSwine
2022 Kia Sorento
Exactly the reason I have a Land Cruiser in the queue. Made in Japan.
The Toyota and Lexus that come out of Japan have had issues in the past as well.
CuriousTaco
Seattle
TRD OR Base
Sorry to hear you're going through this situation.
Seems like an opportunity for aftermarket to come up with some kind of support bracket to avoid the full catastrophic failure of the top mount... Makes me anxious after going down washboards a little faster I should have been 😳
Planoman
DFW, Texas
Which plant was your Tacoma built at? The Tijuana plant is new and that could be the source of the problem. I also questioned the new design when I first saw it, so it could also be poor engineering. Considering what the 4th gens cost there is no excuse for either poor build quality or engineering.
Are they giving you something to drive while you wait, since they said it could take a while to get parts? At least they are not trying to sleaze out of the warranty coverage.
unless it is a new one in Tijuana, it is not new. It has been making Tacoma since about 2004?
R.A.N.M.J.
Rick
Dallas
2021 Bronco, 2023 4Runner, 2024 Tacoma
There's a new plant in Guanajuato that opened a few years back, wanna say 2019. 4GTacos are being built there. 3TY and 3TW models are built there.
The plant in Baja is the old plant, but they're also building 24's there. That's the plant mine originated from. 3TM models are being built there.
My bad. The Tijuana plant is not new, but it might be new to Tacoma production? And that sounds about right for the Guanajuato plant which I remember being about 5 years old.
Either way this failing top hat is probably a component supplier issue as others have said, and not an assembly problem.
Deleted User 1813921
Guest
I have been avoiding potholes and storm drains when I leave the forest to go to the city for supplies. I also look for this after I do hit bumps and every time I think I will see it blown out. If and when a aftermarket solution is available I will be considering it even tho I will not be doing aggressive off road.
GimmeAtaco
Jason
Phoenix, AZ
I was told it could take a while to get parts
Toyota is backordered on parts for the 4G tacoma on most everything. I am still waiting for running boards. I may ask for a parts credit and go get Rock Sliders from Wescott.
UT
I just received my TRD running boards that I ordered for the 4th sale a couple days ago. So it seems like accessories are taking 2-3 weeks generally.
Wags
Banned
Banned
PA
2024 Tacoma Off-Road Premium
not accurate at all, it all depends on the parts. and if it's a main part it will take longer
