On my SR5. So far I got the seats out and the trim around the front and side edges. The "tub" storage thing is next and looks like it will come out easy with a few pop pins. The tub is supported by a metal frame that also looks like it will come out (bolted to the back wall and floor I think). Not sure I will remove the frame tho as the blocked off space under the rear passenger seat has a big junction assembly of wires, which I do not want to touch. After I see whats under the tub I will likely put it back and make a hinged plywood lid to cover it. I will remove the seat belts parts and maybe see whats behind the back wall cover. I expect the road noise will be louder, will find out tomorrow.
Update: Got most of the plastic removed, its very easy to get it to this point. It would also be easy to remove that black frame which would open up a lot of usable vertical space (which is what I need), but that assembly of wires is in the way. I suspect at some point I will take out the frame and make some sort of cover for the wires, but for now I'll just leave the tub in place while I figure out what sort of platform to put in there.
