TRD Pro Hood Shake / Rattle
StreeTaco
They all shake, pro is more prone due to extra weight from the “scoop”
sugammadex
DMV
Tacoma TRD PRO
This guy addresses the same thing and Toyota pretty much told him to pound sand. Kinda crazy…
FoxTRDPro
N/A
Toyota really dropped the ball on these new Tacomas..... 70k for a vehicle that has a hood without any sort of vibration testing.
Odzter
San Diego,CA
It’s likely due to the lighter material. Toyota did say that the hood and tailgate are much lighter than the previous gen.
NS, Canada
88rotors would be likely to make a stiffener bracket for it, I know I will once I get my pro, benefits of being a fabricator with a cnc
WhiteLightning
Noah
Perrysburg, OH
2023 Toyota Tacoma Off-Road
Yes, it shakes. Not just on rough roads either. Kind of use to it though.
Does it seem like it just needs tightened down somehow or what? The above video doesnt seem like its a rough shake, thoughts?
sugammadex
DMV
Tacoma TRD PRO
My shake is the same as the video. It’s annoying for sure
Wighty
Rob
OC, CA
2021 TRD Off Road
I don’t think tightening down will fix it. The video is exactly how mine shakes as well. I think it’s more pronounced on the Pros because it’s raised.
entropy
Crossover
My pro has this also, shakes a ton. Noticed it immediately on the drive home from the dealer. That being said the road was bump af and my tires were overinflated, as well as the suspension being on setting 2. I haven't updated my tire pressure or suspension since I haven't been home, but the other times I drove it around town I didn't notice the shake as much so I probably got used to it. When I get back i'll adjust tires and suspension and see if it helps.
Bluznvice
West
Same shake as my OR. The hood is just flimsy with no support built in. I compared it to a 24 4 runner TRD Pro, and that hood is very stiff. You can definitely tell they skimped on the stiffening.
Wighty
Rob
OC, CA
2021 TRD Off Road
When he mentioned the suspension on setting 2.. I assumed that was the medium setting and he advised to put it on setting 1 for a better ride. Wouldn’t that be stiffer??
