brentbba
My other FT-8800 stayed with the Landcruiser when I sold it. I don't want to do anything permanent until I'm more comfortable with the truck and where I want everything.
We haven't installed a radio in the 4g Taco, but we do make a mount that works with both ditch lights and antennas (1/2" hole.) I actually switched to this mount setup in my 3G Taco as well.
https://www.victory4x4.com/product/VTDLM-4G.html
That's a nice looking installI called them and they measured the bracket and it is big enough I can drill to enlarge the hole to 5/8" for thee antenna base. So I ordered a set. Likely only need the drivers side
I installed the faceplate and also the microphone using zip ties for the microphone holder
Thinking of running the main unit under the rear seat. Still pondering.
I ran the wires from the engine bay back to the rear cab, but haven't hooked them up yet. Left the fuse out of the fuse holder for safety
That was what the HAM guru at HRO recommended. Not sure if HAM antennas come in 1/2"Looks great! Just curious why you choose 5/8 over a 1/2 hole antenna mount? Just more mount/cable options?
Good call on holding the hood. Sometimes I mark it with a sharpie just in case.
No problem, appreciate you showing the research on that, just curious so we can let any other customers that ask know.That's a different kind of mount, an NMO which is what I have on my other vehicle. When I described my setup and the bracket I was recommended this mount instead. I don't recall the reason. This antenna setup is lighter weight with the mount and the antenna, likely not by much though.
In any case I showed your bracket works with the 5/8" mount
