ridetime
You have to lift the bed cap up and you will see a white styrofoam block. I put the tape between the underside of the rail and that block. Be sure to put weight on it long enough to setup properly.I have the same thing going on with my 2024 Taco also. Very annoying. Can you send a pic of how you used the tape for your bed cap? Does it bond well even though the edges of the cap is so thin?
