Deleted User 1813921
Guest
My defect is exactly in the same spot and the condensation is how I was made aware of it. Happened at around 3100 miles.
Glad Iām not the only one. But sucks - I hate having the dealership messing around trying to fix things. It usually opens up a wormhole.My defect is exactly in the same spot and the condensation is how I was made aware of it. Happened at around 3100 miles.
Seems they are all raising up off windshield in that exact spot. I just wish I noticed that rear door window seal at the same time because I have to call the dealership for the second time this week. I am patient and will let the warranty cover everything. Love the truck so much and like you hope this is a ONE TIME replacing defective parts and done deal.Glad Iām not the only one. But sucks - I hate having the dealership messing around trying to fix things. It usually opens up a wormhole.
You seem to have a thing for SheldonGee. What would Sheldon think about thisā¦.its unacceptable from toyota, they need to get their shit together
I have the same problem with condensation in that spot of the lower windshield.My truck is sitting at the dealer for 3 weeks and counting for the cracked evaporator box issue.But itās not solely esthetic- I get condensation on the outside of windshield exactly where my defect is. This pic was taken midday at 75 degrees. Not too hot not too cold. Happens every day.
I'm in Canada,so no lemon law here.I really like the truck during the time I've had it but not too happy now.Ive got a 2023 sr5 loaner and I can see why I never wanted to buy the 3rd gen,but damn it'll probably be more reliable than the 4th Gen.It seems that Toyota needs to either get better at fixing this stuff or get better at making their trucks in the first place. I may get my truck this week and if it has any of these issues I may just walk away. My Tundra is over 13 years old and perfect, something I don't know that I will be able to say about my new Taco.
Good luck @DaveyJ. You are well on your way to a lemon law case if you are no longer committed to your truck.
Mine started lifting up in the same area. I have to agree that I think it's mostly cosmetic although I guess maybe a tad bit of engine heat could be escaping? I used some trim tools and got that area lifted up, then put a thick application of clear silicone under it. Wiped the excess and then sat a couple 10lb dumbbells against it for 24hrs. Nice and flush again for now. Haven't had any odd condensation either before or after.I have the same problem with condensation in that spot of the lower windshield.My truck is sitting at the dealer for 3 weeks and counting for the cracked evaporator box issue.
This was my exact thought process and plan b if the dealership told me it was cosmetic and not to worry. The technician that called Toyota to confirm warranty replacement was told it was a known issue and advised to order new windshield cowl. Now I will say this if it raises up again on the new cowl I might be doing a lil silicone and dumbbells in my own bat cave. Nice work and great tips with the dumbbells as weights.Mine started lifting up in the same area. I have to agree that I think it's mostly cosmetic although I guess maybe a tad bit of engine heat could be escaping? I used some trim tools and got that area lifted up, then put a thick application of clear silicone under it. Wiped the excess and then sat a couple 10lb dumbbells against it for 24hrs. Nice and flush again for now. Haven't had any odd condensation either before or after.
While I had the strip lifted up, I found that the plastic underneath sits very tightly against the windshield, that's why I'm also kind of voting cosmetic but I really have no idea.
Edit to add that dumbbells also fixed my rear bed caps coming up at the front. A 25lb on top of each for 24hrs got them flush against the bed. Over 2 weeks now and they haven't budged, fingers crossed it stays that way.
