Plumbers 1st Taco
Getting yours in the shop soon?
I got a feeling mines on its way out. I get some weird shifts here and thereVery minimal, feel it a tiny bit when it is downshifting coming to a stop. Really not noticeable when accelerating.
Too bad about the codes - this is the one time when you wish that there were some there.So I scanned my truck tonight and zero diagnostic codes are stored in the computer . My trucks drives fine other then some weird shifts here and there
Yeah exactly but the weird shifts are not frequent enough for them to probably feel it.Too bad about the codes - this is the one time when you wish that there were some there.
I have only about 200 miles on my truck but it seems to shift perfectly and you can barely tell that the shifts have happened. How can you dealer explain how your truck has some weird shifts when some other Tacos shift smooth and clean every time? It can't be normal unless all the truck behave the same way, right?
That’s the one thing about that tsb Toyota put out that pissed me off, they gave zero info on what issues customers might expierence in relation with the dtc codes that get stored in the computer.Too bad about the codes - this is the one time when you wish that there were some there.
That is true. I get the feeling that a solenoid does not throw a code until it won't work at all, which is why the transmission stop shifting into some gears. But you have to wonder if your weird shifts aren't just a sign that they are damaged. Then you have to wonder if that is all that will happen or if they will get worse in time.That’s the one thing about that tsb Toyota put out that pissed me off, they gave zero info on what issues customers might expierence in relation with the dtc codes that get stored in the computer.
Yup and I’m hoping they come out with an updated bulletin on the matter to clear the air. The fact that pro models and trail hunter models have failed as well is concerning because they aren’t even listed on the tsb sheet.That is true. I get the feeling that a solenoid does not throw a code until it won't work at all, which is why the transmission stop shifting into some gears. But you have to wonder if your weird shifts aren't just a sign that they are damaged. Then you have to wonder if that is all that will happen or if they will get worse in time.
Good luck.
Yeah I wondered about the halos. My truck is not in any of the ranges but I don't know if the ones that failed are or aren't. It would be helpful to know that too.Yup and I’m hoping they come out with an updated bulletin on the matter to clear the air. The fact that pro models and trail hunter models have failed as well is concerning because they aren’t even listed on the tsb sheet.
Doesn't appear to be, using the form on the very first post in this thread.Can someone tell me if mine falls in TSB? 3TYLC5LN3RT006155
Thank youDoesn't appear to be, using the form on the very first post in this thread.
Looks like we have the same VIN, 3TYLC5LN#RT and we fall on the new TSB posted today.Can someone tell me if mine falls in TSB? 3TYLC5LN3RT006155
