2024 Tacoma hitch lock pin size
Liquidassets
Bronson
Louisiana
2024 Tacoma TRD off-road
Just an FYI, I have a 2024 Tacoma off road with the stock hitch. The pin diameter is 5/8". It seems like the hitch pin should be 3.5" but my Tacoma hitch requires a 4.0" pin.
First, I tried the standard rhinousa hitch lock which was way too short. I then looked up reviews which that stated the 2022+ tundras were compatible with the larger "2.5 inch rhinousa hitch lock" which in reality has 3.5" of usable length. The 2.5 inches refers to the receiver size. This was a barely too short for the lock to engage and had to be returned.
In the end, I needed a 5/8" diameter by 4.0" effective usable length pin. It is slightly longer than it needs to be, but fits after trying 2 prior.
I bought this cheap one which doesn't include a safety pin. I'd be interested to hear if someone can fit a 3.75 inch hitch lock.
2024 Tacoma 2024 Tacoma hitch lock pin size Screenshot_20240303-175042
CuriousTaco
Seattle
TRD OR Base
I remember reading this months ago not really thinking much of it because I didn't understand the issue. When I went to use my locking hitch pin for the first time today I realized the problem... Too short šŸ˜‚ now I get why the truck includes one from factory.
Thanks for doing the research for us!
TrashPanda
Brad
Alabama
2024 Tacoma TRD OR Premium
Hoping Factor55 will make one. Does anyone know why Toyota added an extra box around the hitch. I’ve got a hitch skid to add but I don’t want $250 hanging on the hitch unsecured.
Tom Sellick
Tom
Ontario
2024 TRD Pro
Ran into the same issue with the pin for my Yakima bike rack. Because of the wider Tacoma hitch the bolt wasn't long enough to get the lock in the end. Couldn't find a longer one anywhere. Luckily a friend whose is a millwright made on for me. I'm also wondering why the wider hitch?
Motogator
Wes
I found a locking one at Tractor supply. They had multiple brands in the long length on the shelf.
cyranodabum
Orange County, CA
2024 TRD OR Hybrid
I totally forgot that the hitch pin came with the truck. I tucked all that stuff away the day I got the truck and would never have remembered if not for this post!
Airborne
Upstate,NewYork
Good info thank you, :lying: Now i need to find that included pin, lol
alcarriere
Al
mckinney, tx
2024 toyota Tacoma SR5
I just bought a 2024 tacoma sr5. Went to put my bike rack into the receiver and the pin doesn't fit.
The pin is an anti rattle pin with one end threaded with a 1/2 inch diameter and the other end with a hex head and the last inch is 5/8 inch diameter. it has a 3 1/2 inch shaft.
The bicycle rack has a 1/2 inch hole.
So the setup uses the nut on the threaded end and the 5/8 diameter part of the shaft tpo pull and hold the rack tightly to one side of the receiver.
To clear the receiver in the Tacoma I need 4 1/4 inch shaft.
So try to find a new pin with that same arrangement but with the longer shaft?
Or i get a new pin with enough length and anti-rattle body , 5/8 inch diameter across the entire length. I'll have to widen the hole on the bike rack to 5/8 inch.
Am I on the right track or am I missing something obvious. :-0
thanks for any feedback.
Canufixit
Canu
New England
2025 sr DC 4x
Well, I did not get a new pin.... so I just bought one. Where did the Factory/Dealer put them in the truck ???
john877
Severn, MD
2024 TRD Sport
I ordered a couple of stock pins, Part No.: PT228-0C231, from ToyotaPartsDeal.com. I have a couple of receiver hitches and keep one with each of them. Then were pretty inexpensive, like 6 bucks each, although shipping added about 10 bucks.
Canufixit
Canu
New England
2025 sr DC 4x
I bought mine on amazon... a tad cheaper w/ prime shipping.
Good thing I caught this - because I would have not like to have found out that my original pin was too short when I really needed it.
