2024 tacoma trd offroad rust
Slikka
Michael
Louisana
2024 tacoma
Do you have the windshield cowl defect like 100’s of others of us? Wondering if water has been leaking right there from it? And yes, I would be concerned.
Thank you for mentioning it i do have the defect which caused it to rust
TrashPanda
Brad
Alabama
2024 Tacoma TRD OR Premium
Is this rust happening to gas, hybrid or both? Something worth knowing. That same part is in both versions.
TrashPanda
Brad
Alabama
it can happen to any its a cowl problem
I’m still out on the cowl being the problem. Some of the 3rd gens had the same issue on the cowl. That is literally a rubber piece that isn’t sealed to the glass. Run a hose over that spot and show me water coming into the area in the engine bay and I may change my mind.
Exactly. My 3G had this cowel issue but water never got in. Unrelated
I checked my truck a little more closely and attached a couple of picts. That part is heavy cast metal and most of it is painted black. Where it was machined it is bare metal and mine is rusting too. Since my truck is just a month old these show how it looks when it is just starting.
But surface oxidation is actually protective and can stop rust eating into metal, so it is probably not all that important. I guess mine will look like @Slikka's truck one of these days and it isn't pretty, but probably won't cause any problem.
I also don't see how water coming in under the cowl would get to this area, and it is more likely just splashing up from the road.
Slikka
Michael
Louisana
2024 tacoma
Thanks for the info unfortunately urs isnt nearly as bad as mine?
It's unpainted cast iron. Mine has a bit of rust but nothing like yours. I live in the dry west, and I suspect you live somewhere the humidity is much higher.
Take an acid brush and paint the surfaces with some light oil. It'll make you feel better, but without oil, that part will still last longer than your truck.
Taconatron
nathan
2024 tacoma
You don’t need direct water splashing onto a bare metal surface to create rust. Just high humidity. That’s probably the cause of most of y’all’s concerns. Possibly splashed from a wet road but it doesn’t need water contact to rush. This is a common thing on cars old and new. Just surface rust. It’s fine. You can sand it down and hit it with a primer if it’s bothering you.
Hingie
George
Coatesville PA
2024 Tacoma Sport
Wow. People here get super irate over normal non-painted surfaces that get some rust due to moisture / humidity. Its an engine that is exposed to the elements. It's normal and as someone else stated above, will still outlast the truck. Sheesh
While I agree (much like the transmission issue is being blown way out of proportion), it does seem that the defective cowling is exacerbating the problem. That or OP just lives in an exceptionally moist area.
Yeah - the part is in no danger of failing - it is cast iron and probably more than 1/2 inch thick.
Rusting parts like this are common on the chassis but it is unusual to see it this bad in the engine compartment. Maybe that is why so many modern engines are hidden away under covers.
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Well, most of us old farts never saw rust on an engine before because they were always covered with grease from all the leaky valve covers:)
