285/70/17 tires with or without lift?
keonigt
Hawaii
2024 Toyota Tacoma
703 method on a plus 35 offset
That setup looks great!
Are the tires flush with the fenders? I would like to run this setup if the tires/wheels are flush and not poking.
keonigt
Hawaii
2024 Toyota Tacoma
I installed a full-size 285/70 r17 under the bed. It fits. The tires are wider but honestly I think it kinda looks badass with the bigger spare. It looks like it might impact my departure angle, but the tires are built to support the weight of the truck and they might even protect my trailer hitch a bit. Definitely it will get me home if I ever need it. Stock suspension and wheels, no mods to exhaust. Nitto Ridge Grapplers.
Love the look bro!
What wheels and specs are they?
I have not, I read on another thread that it might fit aired down and with the axle dump exhaust installed.
I haven't seen a picture of someone actually installing a full size down there yet though.
I fit a 33.2” tire under the trail hunter zero issue
285/70/17 is easy mcpeasy - requires no mods at all. Bigger question is can you get a 285/75/17 with no mods
bsquaredMTB
Ben
El Paso, TX
Decided to pull the trigger on my 285/70/r17 tire upgrade. Ended up going with the Nitto Terra Grappler G3s and I'm happy to report they fit great! I'm headed out to the trails on 3/1 so I'll confirm that there's no rub but from I can tell there's plenty of room.
Here are some before and after pics
2024 Tacoma 285/70/17 tires with or without lift? 20250205_163210~2
2024 Tacoma 285/70/17 tires with or without lift? 20250205_175014
2024 Tacoma 285/70/17 tires with or without lift? 20250205_175002~2
2024 Tacoma 285/70/17 tires with or without lift? 20250205_163227
2024 Tacoma 285/70/17 tires with or without lift? 20250205_175919
2024 Tacoma 285/70/17 tires with or without lift? 20250205_175934
2024 Tacoma 285/70/17 tires with or without lift? 20250205_183440
cnoble
Coleman
United States
2024 SR5 Double Cab 4x4
to yall that have upgraded to bigger tires, did you upgrade tie rods or control arms? if not did you notice any extra wear and tear or sloppy performance? I'm a little nervous about getting bigger tires but I want them so bad. thanks in advance!
bsquaredMTB
Ben
El Paso, TX
I haven't' seen anyone do that for 285s. Not sure if that's necessary, but I didn't notice much of a difference just driving them back from the tire shop.
For 33” 285s? Nah. No way. That’s tame. Maybe, maybe as you approach 35” and even then it’s more like a long term wear and tear issue than anything imminent.
I’m crazy conservative on this stuff and I’ve had 275/70/18s (33.43” x 11”) E loads and now 285/70/17 (32.8” x 11.5”) SL - 60 and 53 pounds. The lighter 285s seem to be gentler tires but like neither of them seems crazy to me. I may go to 34” in the same weight range and I will not be concerned at all. If you run 35x12.5s maybe your bushings wear out faster but these trucks are generally pretty stout.
CuriousTaco
Seattle
TRD OR Base
This looks awesome! I had some bad experiences with the G2's wet weather performance in the past, but the updated G3's look much more promising and seem to fix those issues. This will likely be the route I go once the stock tires wear out. Interested to hear how they work out for you!
cnoble
Coleman
United States
alright, that puts my mind at ease. I'll go out and upgrade my tires soon haha. thanks for sharing!
Now that I’ve had some time with them and have dialed in the pressure - I can say the Falkens in this size are awesome and beefy
