tacogarage
AJ
San Diego
3rd and 2nd Gen Taco
Hello,
I did a quick search and didn't see any of these posted for the 4g taco so I figured I'd share some useful torque spec information.
THESE ARE FOR REFERENCE ONLY!!!!
These values may not the same for every taco, they are all going to be very similar and in a lot of cases the exact same, BUT, there may be variations and you must do your own homework and double check everything with the appropriate manual. YOU MUST also make sure your torque wrench is CALIBRATED or what's the point!
These were early production numbers so keep in mind that things change with time, updated values may be completely different. MAKE SURE you know what you are doing before messing with your suspension.
That being said...
There are 3 values for each item, they are in the following format... N*m (kgf*cm, ft.*lbf)
Hope this helps.
IF YOU NEED ANAY ADDITIONAL VALUES, PLEASE REQUEST BY COMMENTING HERE.
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 124816
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-05-14 105552
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 124852
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 124929
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 124942
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 124958
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 125021
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 125033
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 125052
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 125109
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 125129
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 125138
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 125149
2024 Tacoma 4th Gen Tacoma 2024+ Suspension & Wheel Torque Specs Guide Screenshot 2024-04-26 125237
tacogarage
AJ
San Diego
If anyone needs any other values just let me know by commenting here, you may not be the only one.
4GTD
Detroit, MI
2024 Tacoma TRD Off Road
maybe i missed something, but whats the torque spec for the lower control arm cam bolts?
Yotota
Zane
SW WA
24 TRD
I'll second this.
@tacogarage - can you please post the specs for the LCA bolts? I just ordered your strut mount plate spacers so I'll need that spec soon! Thank you!
