Thanks!! Everything seems to be working for now … but if it stops, I now know the problem and how to avoid it!Hi @PDL ,
This issue is simple and we see it in a ton of different dashcams on the market (btw, it has nothing to do with our adapter or the dashcam power). Most dashcams use a combination of wifi + bluetooth to connect to your phone, but so does Carplay and your phone can't connect to both devices at the same time. Likewise if you use Carplay, you will not be able to connect to the dashcam simultaneously.
Your best bet is to 'forget' the dashcam in Bluetooth and disable autojoining the Garmin's WiFi network or just delete the Garmin's wifi network from your list of networks. After all, you'll only need to connect to the dashcam if you need the footage, and it only takes a minute or two to rejoin the Garmin.
