Decal Removal
thesmitz
I used a rubber wheel to remove the OffRoad decals from the sides of the truck but there is some noticeable discoloration now if the sun hits it just right.
Trying to figure out if there is some residue left that I need to take off or if I stripped some of the exterior protection and just need to apply some wax.
Thanks
2024 Tacoma Decal Removal IMG_6777
MustardTiger
TacoMAX/Tundra/SDuty/Dmax
Try a mild compound (mild!) with a light cutting pad (orange), and a dual action polisher on medium speed. That should remove anything remaining, just keep in mind it cuts the clearcoat a tiny but.
max911
max
AB Canada
It is either a bit of residue left, or the clear coat is cloudy from over heating (friction from the rubber wheel)
I would try some adhesive remover first, just in case it is residue.
If that doesn't work, then go with MustardTiger's suggestion.
I always like to start with the least invasive method.
I would go with @MustardTiger's suggestion, but doing what @max911 suggests can't hurt anything and would clean off any debris from the rubber wheel.
You just have to hope that is damage to the clear coat and not areas where it is gone. Good luck and let us know what happens.
thesmitz
thesmitz
I used some GooGone but it didnā€™t make much of a difference. Iā€™ll go with @MustardTiger suggestion. Worst case scenario, Iā€™ll just put new stickers back and pretend like nothing happened :)
Dirt
Greg
Eastern OR
My body and fender guy says he doesn't use a buffing wheel on new Toyota's anymore. The heat can eat thru the water based clearcoat and thin paint to bare metal in 30 seconds. Be careful. (He also knows I'm more like a bull in a china shop than an artist.)
Frog Mack
Frog
Mississippi
24 Tacoma TRD OR, 14 FJC
Hope itā€™s just a tad of residual adhesiveā€¦ keep us posted.
I do find it interesting that some folks want to buy TRD stickers to put on non-TRD trucks, and some folks wanting to take the stickers off the TRD trucks.
not dissing, just an observation. I like the decals, but the hardware (locking rear diff) is more important to me than the software (decals).
thesmitz
thesmitz
Hitting it with the DA with mild compound and an orange pad seemed to do the trick. Thanks all. Likely wonā€™t be doing this again in the future with the rubber wheel.
This is a couple hours after I cleaned up that section.
2024 Tacoma Decal Removal IMG_6845
goin2drt
KY
All is well looks good. I got lucky. Day one let sit in the sun. Peeled right off in 2 minutes no residue left but a little white piece my thumb rumbling got it up.
Slappy
tacoma , highlander
yeah that leave it out in summer sun works well for the badges as well but use some fishing line between the paint & badges , the fishing line cuts the adhesive like a cheeze cutter šŸ˜Ž
Congrats @thesmitz - that is great news. A Bronze Oxide Taco is really pretty, which makes any damage just that much worse. I bet a lot of people learned a lesson on that one.
thesmitz
thesmitz
I was impatient and after a week of no sunny days, I decided to take matters into my own hands. Learned my lesson.
Airborne
Upstate,NewYork
Happy to hear all worked out for youā€¦..take a deep breath all is good buddy,
Norsk
Greg
Downingtown, PA
Here's mine! Took the decals off. I was looking at this and thought it would blend nicely on my truck with underground gray.
2024 Tacoma Decal Removal IMG_3749
2024 Tacoma Decal Removal IMG_3676
