Failing the 4H Test?
I don't understand why you need to test the 4wd.
Once it is engaged the indicator stops flashing and you are in 4wd. It behaves differently in lo and hi, as expected. But if it fails to engage 4Hi the indicator will keep flashing and that is when you need to worry. Otherwise just drive it and don't worry.
MHG
Mark
Long Island
2025 TRD Offroad
Because the pop that brought my neighbors out of the house when making a u turn after disengaging the 4H makes me want to check to see that it’s not broke. Recoveries off the beach in Long Island costs thousands
Mine has popped as well. It’s fine though.
MHG
Mark
Long Island
2025 TRD Offroad
Good to know. $65k on a new truck. Want it to work. Thanks for having the conversation with me. đź‘Ť
Yeah I was pretty freaked out as well. Then when everyone said the same thing I stopped worrying. My 3G shifted smoother in and out of 4WD but it was also a shit load more finicky. I think the trade off is that the 4G is more forceful in shifting into gear but in being more forceful the gears aren’t always meshed up perfectly and cringey sounds come out. Hence the benefit of moving slowly when you shift into 4Hi.
Airborne
Upstate,NewYork
Lol, we got a heavy snow, roads were closed, schools closed…i said to wife time to play… burried truck, activated sway bar disconnect and thought okay 4 wheel drive is great…….COME ON DRIVE UP TO CURB….. THAT GOES RIGHT ALONG WITH THE “ bit coin oin “ bullshit lmao
OK - I'm with you on that and you should get it checked out.
Did your dash display show it out of 4H when it made that loud pop? If it is still flashing then it is still engaged and a tight turn would put a lot of stress on the drivetrain. I would take it to the dealer and have them check it out and I would not mention the u turn and the pop.
