Heated Steering Wheel. Possible Issue.
Randyg
Randy
OK
2024 Bronze Oxide LTD; 2008 Speedway Blue Off-Road
The individual areas [top, top sides, bottom sides] independently cycle ON/OFF. I haven't noticed a cycling pattern yet as I have only used the feature a 'handful' ;-D of times. I find myself moving my hands to the warm spots as I drive. It's like doing the Macarena as I drive.
bresna
Kevin
2024 TRD Sport
On other Toyotas that I've had with heated steering wheels, only the padded parts of the wheels were heated. I don't think they have a heating element in the hard plastic areas. I think it's just hard plastic molded over a metal core.
Goriders
2024 Tacoma Sport Plus
I just turn mine on for a few minutes to warm it up then I shut it off.
massm22
Ron
Boston
Before I schedule a dealer visit. Anyone here with a heated steering wheel, does the top of your wheel get way warmer than the bottom? Also do you notice the steering wheel is on a heated cycle. The steering wheel in my truck will get warm and then cools off and warms up back to temperature? Any input would be appreciated. Thank you.
I’ve noticed that too. I would venture a guess that it has something to do with the design of the wheel itself. I would guess it’s cooler around the conduit where the control wires enter the steering wheel.
Goriders
I’m assuming it’s just heat tracing so it would have to be in areas with material that could transfer heat. Guessing they think the majority of people would use the top half of the wheel most of the time.
emidyl
Henry
Toronto
N400 Sport Prem
today was the first time I ever noticed it "cycled" or reset. I actually thought it went off but light was still on. I toggled the switch and the heat came back. I don't usually leave it on for much longer than 20 min but its friggin cold here today and was on almost 30min. Mine heats up like pretty much everyone elses, gets super hot in ctr area then followed by the upper edges. THe ctr bottom I don't even remotely feel heat, the bottom sides are warmish.
