Is my transmission supposed to sound like a diesel tractor?
Delta1Seven
I just bought a 24 Limited. Currently have less than 250 miles on it, but I can't help but notice that it sounds like a diesel tractor when I shift it into drive. Is this a normal noise for these trucks?
According to the TSB, my truck is not inside the effected VIN range.
Sounds like mine, so if yours is fucked, so is mine!
Ron
Vancouver Island
I dont think mine does that.
Sounds like a chattering solenoid.
Delta1Seven
Delta1Seven
What really grinds my gears (no pun intended) is Toyota bought back my 24 Tundra because of transmission issues. Really annoys me if my tacoma will also have similar issues.
Tacoscott24
Tennessee
2024 Tacoma SR5
Mine sounds the same way. I figured more than likely it’s the direct injection system on the engine once under load aka drive makes the direct injection kick in more due to the load. Hence when it’s in park or neutral it’s not under load so it’s quieter.
Delta1Seven
Delta1Seven
Interesting... Toyota actually bought back my 24 Tundra recently due to Transmission issues. I was really hoping I wouldn't hit on 2 in a row.
Does yours also make a "tick tick tick" sound in park rhymatically (in a 3 tick beat?)
Ron
Vancouver Island
I put the phone under my truck and it does flutter more when it goes into gear. Doesn't sound as pronounced as the recording in the OP. I didnt notice it before.
Jimbo
Jim
2024 SR5
Jimbo
Jim
2024 SR5
2024 SR5, less than 200 miles, sounds like you describe.
32spoke
Jason
Petaluma,CA
That’s your engine’s fuel delivery, not the transmission…
Burgi
NC
24 Taco
that's the high pressure fuel pump for the direct injection. You can use a screw driver to listen to it and you'll hear that distinctive clicking.
According to the TSB, my truck is not inside the affected VIN range.
Totally Normal.. This little Turbo4 makes some weird noises! However my 2013 Tundra 5.7 was louder and was trouble free until I sold it at 150K miles.
