trailhunger
US
2024 TH
do you know where they tapped 3rd brake light for your smart cap?
trailhunger
US
2024 TH
Still waiting for my harness but the instructions show it plugging into the trailer connector.
Do you know off-hand if Smart Cap waiting for this from Toyota or an aftermarket supplier? I'm guessing if you get pulled over for this it's basically a warning after explaining you're awaiting parts?
It's definitely a Smartcap part, not something from Toyota. Once the hole is drilled in the bed, it's a five-minute plug-and-play.
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Wiring harness came in.
It's from a 3rd-party manufacturer in South Africa.
Comments on the installation below.
2024 Tacoma SmartCap Adventure Topper Installed IMG_20241017_125752440
Biggest pain was drilling the hole. Metal is thin there so the bit wants to grab and deform the surface.
2nd biggest pain was that the t-cable was soooo long. Ended up rolling it up and tying underneath instead of trying to cram it alongside the soft-opening strut for the tailgate.
Next was something I found disconcerting. After I did the initial hookup I propped a weight on the brake pedal, and no light! Turns out it only works when the engine switch is on.
Lastly, no grommet included for the hole. Naturally, I didn't have a 3/4 grommet in my boxes and boxes of stuff, so, a trip to the parts store and now I have 3 spares.
Am happy it's all done though.
Franko Manini
Frank
Victoria, BC CANADA
Tony, Do you have the power tailgate? I would like to know if you can open the tailgate without opening the back hatch. My guess is yes otherwise if someone hit that button the hatch might be damaged... but I'm interested to know for use. Considering getting one this week.
Thank you!
I do. And yeah, you can hit the switch and the tailgate will open without opening the lid, but generally, it won't close with the topper door closed.
Franko Manini
Frank
Victoria, BC CANADA
Rats. I really don't like having to unlock and lock the two latches every time I need something out of the tuck bed.
