To prefill or not to prefill oil filter?
prmtime101
Michael
Tampa, FL
2024 Tacoma SR5 4x4
Hey guys and gals,
I hear pros and cons for prefilling the oil filter during an oil change. I have read a lot of posts arguing both sides. I did not prefill my oil filter on the last change, but I think that I will from now on. The 2024 Taco's oil filter is horizontal so I am not sure how much good prefilling will do. Did I harm my engine by not prefilling the oil filter? It was my 1,000 mile break-in oil change. What do you all say? Thanks!
Over 40 years of changing oil hundreds of times, I've never prefilled a filter.
Pappy
Jon
Albuquerque, NM
I prefill when I can (filter orientation). There are no cons to prefilling.
Burgi
NC
24 Taco
I've never prefilled any oil filters on motorcycles or cars.
Vidman
Rick
Mass
I prefill when I can but you won’t hurt the engine if you don’t.. one of my best friends builds racing engines so that’s why I do it
I do all of my own oil changes, and I have never prefilled an oil filter, so it can't be necessary. It can't hurt if it is possible, but not really needed. Watch your oil pressure when you start your engine and see how quickly it reaches normal pressure. Years ago some people would remove the coil wire so they could crank the engine and build pressure before allowing it to start, but I haven't seen that done in years either.
As others point out, it would run out and make a mess on most Toyota engines anyway because of their orientation. So you are basically starting with a mostly dry filter every time you start the engine.
diverjm
Jordan
CA BayArea
24’TRD OffRoad
I prefill enough to allow the filter media material to be saturated but not over saturated to the point it pours out when installing horizontally.
