What gas are you using?
What Octane?
  • Total voters
    80
Burgi
NC
24 Taco
What fuel type are you guys using in your 2024+ Tacomas?
MTTH24
Ofrode
TH on way
We have 91 No Ethanol, so run that during winter to minimize condescension. Totally unscientific, but got 22+mph over 25 miles on the last tank (highway). When the cold breaks, will go back to 89. Most economical and engine rated.
Daveintb
Tampa
Chevron 93. I’m a big believer in high detergent gasoline. Shell is my # 2
Mtnbikes
Minnesota
Always use top tier fuel. Download the app and no matter where you are it will locate a station for you that uses top tier fuel.
2024 Tacoma What gas are you using? IMG_4556
RokeHi
TRD PreRunner
Brian
The Copper State
I usually use 87 Shell or Chevron unless I'm on a long trip then 91.
EastonTaco
Venice FL & Easton PA
I played around with this for a while keeping track of gas mileage around town over the course of several tanks and on an extended trip. I found I got about 2 mpg more with 91 over 87 octane. I live 5 minutes from Costco where the 91 is only about 15 cents more than 87 so on a tankful with the better mileage it’s almost a break even cost. Also, maybe just me, but the truck seems to run better and less engine noise with 91. I’m hooked on 91 from here on out.
LincolnSixAlpha
Brian
Phoenix
Generally use 91, but on occasion will drop to 87. If I'm on any kind of long distance road trip, it's 91 all the way.
chasea1989
Chase
Las Vegas, NV
2024 Toyota Tacoma SR5
Been running 87 since I got the truck, no issues so far. Tried 91 on one tank and didn't really notice a difference
Lennyz1
Len
NY
2024 Tacoma TRD Sport Hybrid Bronze Oxide
Ran 2 tanks of 91 ethanol free, then 2 tanks of 93 W/10% ethanol and now ran 4 tanks of 87 W/10% ethanol and see the 87 is putting up the best MPG. Winter blend and single digit temps are probably screwing with my MPG number a bit. I will probably settle in with 87 since mileage will be slightly better and the cost is about $8 per tank less.
