Carista app, what have you done??
Anyone know if there’s a physical data screen I can buy that ties into Carista so I can have a constant display while driving instead of having to look at my phone
ramble22
2024 Tacoma Limited Hybrid
I am intrigued about Carista... and, I would like to purchase it... However... I am turned off about having to "subscribe" to their service just to use it! If I only subscribe for the first month, make my changes, and then "unsubscribe", do the changes vanish? And, what if the company goes out of business one day, or, simply stops supporting it?
FYI, everything done with Carista can also be done with a knockoff Toyota Techstream cable from eBay. That approach will cost you $30 upfront and no recurring cost, but does require more technical knowledge and a Windows computer. Legacy Techstream does work on the 24 Tacoma even though only the new Global Techstream is officially supported.
JoeMongo
Jonathan
SF Bay Area
2024 TRD Offroad, Premium, MT
Only thing I've done is disable the seat belt chime, adjust how long the turn signal stays on and turn off the fake engine noise.
I would like to have the brake activate automatically so I don't need to hit the button each time I start the truck but don't think you can.
What have you guys done?
Hey there Wags, can you tell me where the fake engine noise delete is? I just got Carista, took a look around my truck yesterday, and I could not find any engine sound enhancement parameter in my TRD OR premium. Perhaps there are only certain specific Tacoma models that got that non-enhancement, but your build looks similar to mine.
j.
Wags
Wags
Banned
Banned
PA
2024 Tacoma Off-Road Premium
j.
I have the same truck and its in there some place, I turned mine off 6 months ago so I don't remember where it was. Just look around once you have it connected and you should find it
4g hybrid
It's under "Chassis & Engine". See below for the full download from v8.7 (using the EVO adapter, but I think that only changes update speeds, not abilities... Carista refuses to specify the difference and I can't find anyone that legit tested both side by side)
The following settings were available specifically to your vehicle using Carista:
Chassis & Engine:
Active Noise Cancellation (ANC)
*ON* / OFF
Engine Sound Enhancement (ESE)
ON / *OFF*
Dings & Warnings:
Warn when doors opened with headlights on
*ON* / OFF
Seat belt warning ding (driver)
ENABLED / *DISABLED*
Seat belt warning ding (front passenger)
Seat belt warning ding (rear right passenger)
Seat belt warning ding (rear left passenger)
Seat belt warning ding (rear center passenger)
Heater & A/C:
Increase blower level automatically when defroster is ON
*YES* / NO
Temperature dial calibration
-2 °C (28.4 °F) / -1 °C (30.2 °F) / *NORMAL* / +1 °C (33.8 °F) / +2 °C (35.6 °F)
Ambient temperature calibration
-3 °C (26.6 °F) / -2 °C (28.4 °F) / -1 °C (30.2 °F) / *NORMAL* / +1 °C (33.8 °F) / +2 °C (35.6 °F) / +3 °C (37.4 °F)
Instruments: Displays & Nav:
Instrument lights restoring sensitivity
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Display odometer after ignition is turned off for…
*30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
Microphone sensitivity
Speaker volume
Lights: Automatic:
Auto headlights activation threshold
Lights: Exterior:
Lane-change turn signal auto-flasher count
OFF / 3 FLASHES / 4 FLASHES / 5 FLASHES / 6 FLASHES / *7 FLASHES*
Turn signal click volume
*LOW* / MEDIUM / HIGH
Coming-home lights duration
OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Turn on marker lights when vehicle is unlocked via remote
*ENABLED* / DISABLED
Lights: Interior:
Turn on interior lights when you shut off engine
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Locking: Automatic:
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / *60 SECONDS* / 120 SECONDS
Locking: Beep & Blink:
Blink hazard lights when vehicle is locked via remote
Locking: Doors & Alarm:
Warn (beep) when a window is still open when locking doors
*YES* / NO
Locking: Smart Key:
Touch-to-unlock-doors minimum duration
OFF / SHORT / *MEDIUM* / LONG
After locking with smart key, don't allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Parking Sensors:
Activate parking sensors in neutral (N)
*YES* / NO
Front center parking sensor range
SHORT / *LONG*
Front corner parking sensor range
SHORT / *LONG*
Seats & Steering Wheel:
Seat airflow level
NORMAL / *SILENT (HIGH)* / SILENT (LOW)
Windows & Sunroof:
Open windows and sunroof via long-press on remote
*ON* / OFF
Open windows and sunroof by turning and holding key in door lock
*ON* / OFF
Close windows and sunroof by turning and holding key in door lock
*ON* / OFF
Other:
Panic function on remote
Obtained with Carista 8.7
4g hybrid
Maybe it doesn't exist in the Manual transmission? Since they don't know what you're going to make the rev and shift points so they can't predict and align the sound support (imagine getting a rev enhancement when pressing in your clutch).
Just a thought.
i turned the "fake" (i don't think it's actually fake, it just slightly amplifies the real engine noise through the speakers) engine noise back on before my subscription ran out. but i don't care even if it is fake - it sounds better with it enabled.
I did the same thing - turned it off, drove it for a few minutes and turned it right back on. Fake or real it sure sounds a lot better with it than without it to me.
That should be a new option, "Tune your engine sound". I want "V8 with free flow exhaust"
Yeah, that would be awesome. The sound from that glorious V8 with the TRD exhaust system is one of the things that I do miss about my Tundra.
Same, I had a Dirty Deeds custom tuned catback system. It was glorious.
JoeMongo
Jonathan
SF Bay Area
Just a thought.
You may have the answer there. I don't even have the Chassis and Engine option listed when I open Carista. I sent in a question to them, but your theory makes sense.
I think I have everything else in your captured list. I even selected almost all of the same settings as you did.
I did tell the truck to stop turning on the lights every time I walked by it.
re:
"Turn on interior lights when smart key in range"
*YES* / NO
I chose NO.
j.
Tacoma nut
Seattle, Washington
2024 Tacoma Hybrid Limited
Chassis & Engine:
*ON* / OFF
ON / *OFF*
Dings & Warnings:
*ON* / OFF
Heater & A/C:
*YES* / NO
Speaker volume
Lights: Automatic:
Lights: Exterior:
Lights: Interior:
*YES* / NO
*YES* / NO
Locking: Automatic:
*YES* / NO
Locking: Smart Key:
Parking Sensors:
*YES* / NO
SHORT / *LONG*
SHORT / *LONG*
Seat airflow level
Windows & Sunroof:
*ON* / OFF
*ON* / OFF
*ON* / OFF
Other:
Very helpful, thank you
rijc99
The Engine Sound Enhancement feature really should be tied to the drive mode settings. I would like extra noise in sport mode but off in normal or eco mode. Still torn on whether to turn it off or leave it on.
Have you tried turning it off yet? I turned my fake engine noise off, thinking I might like driving my truck better without it. It did lower the sound level a little, but the sound was pretty nasty without any enhancement. Kind of rough and gutless IMO.
In the Tundra they add the sound to make the V6 sound more like the old V8. In the Taco they added sound to make the I4 sound like a V6. After one day of driving it without the enhanced sound I turned it back on and left it there.
