BigDan
MD
Just came across the @NYTOP Titanium Axle Dump Exhaust Tip...
Description:
NYTOP Titanium Axle Dump Exhaust Tip for 4th Gen Tacoma. Replaces the factory rear (axle back) section of the exhaust, providing extra clearance for off-road usage, as well as enhanced exhuast sound and 15 lbs of weight savings.
Direct bolt-on replacement, no cutting or trimming required.
Install video (with resonator delete removal)
Goriders
2024 Tacoma Sport Plus
Are there 2 mufflers in the original exhaust line? What’s in the section he removed?
Second question. I was curious if this mod would generate more room for a larger spare?
av8r
Southern Tier NY
too many
To me, it sounds better ( and these engines do not sound good) with the resonator installed. I'll bet there is a lot less noise in the cab with the OEM setup, too.
av8r
Southern Tier NY
too many
The piece removed is a resonator. It serves several purposes. Extending the exhaust beyond the end of the vehicle (less noise inside the cab, less chance of combustion gases entering the cab when idling, etc. reduced popping, etc)
Goriders
Ok thanks. I just wondered if it was a second muffler in series or a catalytic converter
JED
Southern Tier NY
2015 Tacoma TRD Sport
I wonder if there might be more noise in the cab? It will be interesting to find out
run_ruh
Kansas
2024 TRD Off Road Premium Package 6-Spd (white)
I know the trail hunter comes with it and might be tuned slightly different. I wonder on non trail hunter's after a few miles will it send out a check engine light/code with changing the back pressure on the engine?
Tanrmt09
Tabr
96 Toyota 4runner
Im wondering if just taking the resonator and extra pipe off frees anything other then weight up. That's the pro intake and whatever tune you can get from the pro? Depending on cost. The pro also doesn't have a resonator just a tailpipe from what I can tell.
bking
Bernie
2024 Tacoma TRD Offroad
It might be a little noisier inside, but probably not that much. As was said, same setup as the TrailHunter. I'm getting one for mine. That tail pipe just hangs there like a dirty sock on a shower rod. It just looks bad. I'll be glad to have it gone.
Fast31
Langley, BC Canada
2024 Tacoma Sport Premium
This thread had me thinking, you could easily complete this "mod" for $30 or less by simply cutting the exhaust before the bend and attaching a turndown with a clamp or welding into place. A quick search showed there's some nice stainless steel options. I'm personally not interested but thought I would put it out there...
2024 Tacoma Aftermarket: NYTOP Axle Dump Exhaust Tip for 4th Gen 2024 Tacom + Resonator Delete TURNDOWN
CuriousTaco
Seattle
TRD OR Base
I've been wondering the same thing this entire time... Seems very possible
n118nw
San Antonio TX
Taco
Yeah but then you don't have the bragging rights of being able to say you spent $300 on a $30 part.
Pootklopp
Usa
2024 Bronze Oxide TRD OR
I think finding the proper bolt on flange (is that what it is called?) and then adding the turn down would be best. No cutting required.
