Is anyone else not satisfied with the ride of their TRD Sport? I feel that the ride quality is pretty bad even compared to my 2011 2nd gen Tacoma. I feel every crack and bump in the road. I’m pretty sure that if I drove over a piece of paper I could feel it. The most annoying part is when I’m just lightly on the throttle and maintaining speed, the whole truck seems to be shuttering/rumbling/slugging along. It’s hard to explain but it kind of feels like when you’re in too low of a gear and the vehicle sort of sputters. Even if I throw the transmission into Neutral and I’m coasting it feels the same. As soon as I really step on the gas everything smoothens out. It doesn’t matter what RPM, gear or speed I’m at, it just kind of shutters and slugs along depending on throttle position. I guess when I really step on the gas, it transfers some of the weight to the back and that’s when things start to get smooth. I went through and torqued all the suspension components, motor mounts, drive shaft, tire pressure, tire balance, even tried another set of wheels and it’s always the same.
Does anyone else feel like this? Anything I should look at? I have MR316 wheels with 265/70/17 BFG Trail Terrains (same tires that come on the TRD Off Road).
