Gator Hunter
Melbourne, Florida
The picture shows the passenger rear tire is the problem. I get the same message for the same tire when the temperature drops below 50 in central Florida. I'm wondering if it's the same tire that shows the problem with everyone else.
so weird - it also did it once when I aired down rapidly - I think part of the equation is how fast the tire lost pressure - but I cannot recall which tire it was last time
PanAmericano
Janos
College Station, Texas
Solar Octane 2024 Tacoma TRD Off Road
I think solved the tire pressure screen resetting to trip B issue (at least on my Tacoma, no idea if it’ll work for anyone else). It will remain in place if I set the tire pressure screen, then move the curser back to the center setting screen, then hit the little back arrow button to exit the settings page completely. If I don’t hit the little back arrow button on the steering wheel after moving the curser back to the center then the tire pressure disappears next time I start the truck.
hmmm.. I think I hit the back arrow immediately after selecting the tire pressure screen — maybe I need to go to the center screen first ?
PanAmericano
Janos
That’s my experience it as I’ve been experimenting with it the past few days. If I move it back to the center first then hit the back arrow it seems to stick around.
Goriders
2024 Tacoma Sport Plus
I’ll be trying that. Thanks.
Now that you mention that @PanAmericano I think I lost a setting that I had selected because I didn't do what you suggest. The manual is not at all clear on how that menu works, at least not to me.
GPTaco
Alberta Canada
2024 TRD Sport Premium
I've never even seen this on my display, how do you access it?
Maybe I should read the manual....lol
The issue is that none of the other settings disappear or require a special procedure. I followed @PanAmericano advice this AM for the tire pressure screen. When I leave work I’ll see if it’s still showing.
There are a ton of cool displays you can put up across 3 screens that you can shift left to right - so you get 6 displays - I love it (except this one bug)
Lennyz1
Len
NY
I was just going to add this.
I have not had any issue with my tire pressure screen holding.
PanAmericano
Janos
Update from my previous post: the bug is back and the tire display is again going back to trip B. It worked for 24 hours or so but now it’s back to being annoying.
I don’t think your message got posted - there is a bug in this app for sure as it’s happening to a lot of us
