bsquaredMTB
El Paso, TX
2016 Tacoma TRD Off-Road Premium
Well I took it in to the dealer and they determined it's "working as designed". I find it ridiculous that that's the ONE SCREEN that won't stick. It's obviously a bug but I doubt Toyota will ever look at this
Good old scammer—I mean service departments
Kjc
Anc
2024 Tacoma OR
So if you only use the "Single Meter" and not the default "double meter" with the rpms & mph it seems to stick.... But that's the only way I've seen it consistently stay how I set it...... But I don't like the look of the single meter
what is the single meter
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
I can confirm moving it to the left side of my gauge cluster did nothing. The search for solutions continues
There was a comment about making sure you move the cursor back to the center before hitting the 'back" button to exit settings. Have you tried that?
Kjc
Anc
2024 Tacoma OR
That doesn't work... I tried that also.... It may work once or twice but it still goes away after a couple of start ups
goin2drt
KY
There isn’t going to be one just like there is t going to be one for speaker volume decrease while reading a text that works in every other Toyota we own but this one.
stuckinsocal
24 TRD OR 6MT
Are you speaking about the single RPM meter in the center? I have it set like that and it doesn't stick for me, but maybe I'll swap it over to dual meters, save the tpms setting, and swap it back to single meter.
Kjc
Anc
2024 Tacoma OR
For me I set it while in the single mode and it has stayed for about 5 days so far but could be a fluke... But I've never had it stay in the double gauge mode for more than 3 or 4 startups
