MustardTiger
TacoMAX/Tundra/SDuty/Dmax
This setting is under the Instrument Panel category. Are you sure this "volume" setting isn't for the phone call audio? Reason I say this is because my 2008 Tundra has a hidden menu screen within the factory nav head unit. I forget how to get into it, but know it requires various button pushes and touching pattern on the screen...then it magically appears! Very cool for back in the day. You could adjust mic gain, sound cancelling level, and audio level - but this is all for the bluetooth phone portion of the system. And indeed...it does work
Anyways, I did adjust mine to level 8. Not sure I hear any difference in the JBL system. Have not tried the phone yet. Factory level is 4, if i recall
Josh256
Toronto, ON
2025 Tacoma TRD Pro
...If anyone has any questions, wants to know more, or needs help with this at all, feel free to reach out to me.
This is great news, thanks! Although, I'd want to measure the levels at the JBL amp to insure the input/line levels aren't too high at 8 [which would lead to distortion at higher listening levels] I suspect this isn't the case as when balanced 2 notches reward [in the HU's settings] levels were FAR too low prior to installing the Beat Sonic inline amp.
I'm also *very curious* to see what if anything can be done to improve CarPlay Siri!
webshot
Northern California
I checked my Carista this morning. This option from what I can tell only adjusts the navigation volume, nothing else. This can also be adjusted in the NAV settings.
I haven't found any settings for speaker volume in the JBL sound system either. If anyone has located these I would love to know the location. Thanks!
Iqudayo
2024 Toyota Tacoma
Hello everyone,
I am new here but joined for 3 reasons. The first has to do with the title to this thread.
I inherited a 4th Gen SR5 with upgraded JBL speakers back in late November. I immediately noticed how quiet and crappy the sound system performed. Initially, I didn't do any research on the topic. I had a portable JBL speaker in the past and never thought the audio sounded all that great so I just chalked it up to JBL being a low grade audio speaker company anyway. Mid December, I watched a Youtube video searching for a way to turn off the incredibly annoying seat belt chime. I often drive around on private property, at low speeds, with very little need for the belt as I am hopping in and out of the vehicle quite often.
That video is when I found out about an ODB device called "Carista." It is advertised as being able to unlock "secret features" in some car brands and models. Albeit, with a subscription. I decided to purchase it anyway. The device arrived, I plugged it in, and I subscribed to the service. The device and application does as promised. Several nice features were unlocked. I was able to disable the seat belt chimes, enable the windows to be rolled down via the key fob, disable or lower the sensitivity of the front parking alarms, and many more things. Most importantly, I WAS ABLE TO SOMEWHAT FIX THE JBL SPEAKERS!
In the Carista APP, under the special vehicle customizations tab, I noticed an option for MUSIC AND AUDIO. I clicked it. The only object under this setting was called "volume" i believe and it had the numbers 1-10. Mine was set to 3. I turned it to 10. Immediately, I was able to listen to music at a very high volume by having the stereo only set to 20. Before changing this setting in carista, If I wanted the stereo to be somewhat loud, I needed the head unit to be turned up to 60. Going to 60 would now blow out my eardrums. After some time, I decided to settle on setting the option in carista to 8. Now, I turn the volume to 30 or 35 and it is very loud. 50, and I can't hear myself think and my voice is drowned out while jammin along.
I believe these features accessed by Carista can be accessed by a dealership. I have no idea why Toyota would send a dealer a vehicle with global volume setting set to 3 instead of 8 or 9. I could understand not having the global volume set to 10. As I believe a 10 will allow for a completely unfiltered use of the speakers and potentially blow them out. However, I don't think 8 will cause this issue. I have a computer headset with a tuner that operates similarly. I have the option for 1-10 and i set that, then I control the volume level through windows. Maybe Toyota is just playing it safe so it's virtually impossible to cause issues with the sound system? Either way, JBL speakers are not the best. Mid, Treble, and Bass aren't that great and at the pricepoint of 4th gen taco i would expect something like polk audio or boston speakers. I will say, they are sounding much better now after I adjusted this setting. I would reach out to your dealer to see if they can manually adjust this for you. If they don't know what you are talking about, tell them it's in the same system that allows you to enable opening the windows with the key fob. If they try to charge you, I would tell em to "obsenity" off, and just buy the Carista ODB. I believe i got mine on sale for 40 bucks at christmas with a year of access to the application.
**EDIT** I was recalling the location of the setting in the carista app from memory while typing this. It's very possible that setting is found elsewhere in the customizations menu. Please look around.
Those who are wondering... Carista settings changes will stay persistent after cancelling the subscription. You can also use it on as many vehicles it is compatible with as you want.
so my question is do you have to subscribe to a monthly subscription in order for it to work properly and change settings ?
The Sasquatch
CT
TBD
So was this all BS from the OP? Seemed like an honest post and was really hoping for a fix but sounds like it doesn’t exist….
pnwtacoma
Paul
Portland, OR
pnwtuningllc.com
TRD Pro, LandCruiser, Tundra, Sequoia
Thanks for the DIY with Carista. I've had good luck installing the Beatsonic amp. It boosts the gain and slightly improves the dynamic range for a few benjamins.
