Question for I-ForceMax owners, anyone wash their engine?
VermontTaco
Vermont
2024 TH Ice Cap
Vermont winters are long and harsh, and my engine is a mess. I've always rinsed engines in former cars, but not sure about this one. Anyone washing their engine? Covering anything first? Hybrid wires/parts pose any issues?
MustardTiger
TacoMAX/Tundra/SDuty/Dmax
I don't think it would be a problem. Just not a hot engine, and steer clear of the inverter area, and go low pressure where there are orange cables at the back of the engine. Otherwise it should be fine. No alternator to worry about at least. Have you looked into getting the ARK wheel well splash shields? Supposed to help, I hear
Mightyquinn
Andy
Fayetteville,NC
2025 TRD Pro White/Red on order
While I agree with being cautious when washing your engine you should be fine as long as you aren't too close to any connectors with the pressure washing wand. If you are using a garden hose you would be even safer. Granted I have never washed a hybrid engine but I can't see Toyota or any manufacturer putting connectors that aren't waterproof in the engine bay. If it isn't waterproof then dust and dirt is going to get in there anyway.
I have washed many an engine over the years and have never had an issue. I will usually spray the engine down with Super Clean let it soak and then spray it off with a electric pressure washer that I have just for car washing with a 20° or 30° tip. After I have it fully rinsed I will follow up with a leaf blower to get rid of all the excess water and then start the engine for about 5 minutes to let the heat evaporate any moisture I may have missed.
Just my .02 :)
Tom Sellick
Ontario
2024 TRD Pro
Was just wondering about this the other day especially as it relates to the hybrid parts.
maxman
w.v.
22 bronco wildtrak 2 door/24tacoma offroad i force max
Sprayed mine off several times just use common sense avoid flooding the electrical and the air filter inlet I always start engine after and let run for a bit never had any issues with any vehicles Ive owned
Airborne
Upstate,NewYork
Ill. Keep to hand wipping it , like @tacorancher , me personally my luck id short wires out or somthing , maybe over paranoid, but it would be my luck. Lol
VermontTaco
VermontTaco
Vermont
2024 TH Ice Cap
Just my .02 :)
Good call on the leaf blower
