Oil change interval for 2024 Tacoma 4th gen hybrid and gas engines? Synthetic or conventional engine oil?
Tacosauce
Reno NV
2015 Tacoma V6
Any guidance yet on the recommended oil change intervals is for the 4th gen engines? Do hybrid engines usually have different intervals? And synthetic or conventional oil?
JLD94
JD
Tx
I don't know for sure but my guess is it will be like most other Toyota's, they recommend 10K synthetic oil changes.
Personally if I end up getting one I will be sticking to my normal schedule of 5K synthetic oil changes. Seen to many videos about this and it causing premature wear. A co worker has a 2020 Camry that he says he has asked them about this (they talk him out of anything other than the 10K) when he takes it in for service and they say the issue has been fixed but I would rather have the piece of mind considering I would plan on having it at least 10 years/200K miles
26wx
Lake Erie shore
Subaru Forester
Synthetic, of course. I'll be watching BITOG for the 2.4L turbo UOAs in the Highlander...see if there are any fuel dilution issues. If none and wear looks good, you can probably run the oil changes long.
LordEnzo
Central Florida
2020 Jeep Gladiator Sport S Max Tow
Pending how u drive, and where, determines true length of mileage before oil change. Light drivers that don't put many miles or barely work the motor, good for 7.5k - 10k. Run it ragged, motor always hot, lots of miles, offroading moderate to often, etc... I would do 5k - 7.5k pending how extreme. Every driver is different. The manually will reflect similarly to the above.
PnchDrnk
21 Ranger XLT
I have a '21 Ford Ranger and my regular interval is about 15000kms with full synthetic. That being said I don't do a ton of towing and don't aggressively run my engine while driving so just like LordEnzo said your driving habits really matters.
JLD94
JD
Tx
Never go 10k (15k km) on any turbo charged engine. 5K (7.5k km) max is my thought based on a lot of Youtube watching.
I agree....after seeing so much I can't imagine waiting the 10K personally especially since I have kept my current car for over 200K miles and plan to do the same with the next one.
A co work has a Toyota though and says that the dealer almost fights him on changing it before the 10K
Dmesser92
Dylan
Easley, SC
2023 Toyota Tacoma SR 4WD, 1991 Toyota Pickup 4WD
I've had similar experiences. Some service advisors will fight you on it. I've thought about foregoing the free oil changes and doing them myself, just to avoid the hassle. I feel better about 5k oil changes rather than 10k. It can't hurt anything by being at best proactive, at worst, paranoid.
Tom59
Thomas
New England
02 Tundra ISE, 2012 CT200h, 2015 NX 200t
Depends on where you drive it keeping the air filter changed keeps the oil cleaner. Same intervals we have this engine in our Lexus. I change it every spring and fall but we rarely drive it. Offroading in the desert probably requires more oil changes...send it out for analysis if you are worried. I'm wondering if they require premium fuel. That's a big difference in the price of gas. My Tundra runs on 87.
TacoTime
Forester
iForce Max oil filter location driver side front. Looks like an oil cooler and drip guide. I wonder if there is a way to capture drips without removing bash guard? I normally use an oil vacuum pump through the dip stick for changes so just a bit of oil left in the sump to capture when changing the filter.
2024 Tacoma Oil change interval for 2024 Tacoma 4th gen hybrid and gas engines? Synthetic or conventional engine oil? IMG_0319
Blue Crush Taco
Dare
Ontario, Canada
2024 Tacoma Sport
Dealer recommends 16000 km / 10000 mile oil changes here in Canada. With synthetic oil of course. I doubt anyone would want to wait that long though. ( I know this because I checked the oil service counter and it showed 15 xxx km left til oil service) hope this helps
CATOY
NorCal
I'm planning on changing mine every 5k miles and will not clear it after the first one and have the dealer do the free one at 10k and I will do the 15k and let the dealer do the 20 and then do all the rest myself every 5k miles. I have had several Toyota vehicles along with a few Chevrolet and have always changed the oil much for frequent then the manufacture recommends and have never had any issues what so ever. My father was a Toyota master mechanic for over 30 years and he always stated that an engine's oil is the life blood of the car.
SleepyBear
2024 Tacoma, TRD Off Road 4x4
To answer the question at hand. 0w-20 ILSAC GF-6A, which is only synthetic.
Also, ILSAC GF-6A and API SP are interchangeable and identical specs.
source: family member is a Mobil 1 chemical engineer.
Just do it at 5k / 6 months unless you’re all highway And can do 10k miles in 6 months. Most of us fall under the severe duty, believe it or not. It also includes repeated short trips. Dealers still use non Toyota SN for “Toyota care”, which is the wrong oil.
Ignore the salesman and service managers! Change the oil and filter every 5K miles. There have been a few new Tundra TTV6 engine bearing failures that some suspect could be due to boosted engines and oil changes at 10k?
